  #1
Old 06-24-2011
diego garcia is on a distinguished road
Yanmar 6lya-stp 370hp 6cyc
Hey everyone
I'm new to this sailnet community not sure I'm on the right page but...
I have an issue with my YANMAR starter motor or starting system.
For the passed week I have had intermittent starts, I can the actually starter motor (whizz) rotate but it doesn't turn the fly wheel. It used to kick in and start the engine eventually but now its not playing at all.
I've checked I'm getting 12+volts at the starter solenoid and checked the voltage drop on starting which went down to 9.5+volts, I presume this is correct.
I've checked the starter rely (back from the starter solenoid) and checked the battery isolating switches.
Using a insulated screw driver I created a short across the starter motor terminals but still had the same symptoms as before.
My next move is to change the starter motor???
  #2
Old 06-24-2011
tommays's Avatar
Dropping to 9.5 volts would point out a problem
Is this at the battery OR the starter
If it is at the battery it could be a tired battery
If the battery stays at say 10.8 and the at the starter its droping to the 9.5 i would look at the cable and connection quality
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
  #3
Old 06-24-2011
HDChopper's Avatar
Needing Apehanger Helm
HDChopper is on a distinguished road
sounds like the bindex isnt working correctly if as tommays says the batt holds up 10.8 or better...
bendix's are known for this issue,
There is no right way to do the wrong thing
  #4
Old 06-24-2011
jrd22's Avatar
Courtney the Dancer
Probably Bendix drive on starter like Chopper said.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
  #5
Old 06-24-2011
Omatako's Avatar
Omatako will become famous soon enough
Yep, what the others said, the bendix is not kicking into the ring gear.
Take the starter off and see if it just needs freeing up and lubricating, you may get lucky - they do get sticky with limited use.
Arthur C. Clarke
  #6
Old 06-24-2011
tommays's Avatar
From my POV if the starter is spinning BUT not turning over the motor and dropping to 9.5 volts its NOT getting the correct current
Tommays
Northport NY
  #7
Old 06-27-2011
Cheers for all the help guys.
Just removed the starter motor... bendix and cog were covered in thick rust!!! it didn't even turn when I put a battery on it. Engine is only 80hrs old!
You may post attachments
You may edit your posts
yanmar gm ray1 Diesel Engine Forum 0 05-04-2010 03:16 PM
Yanmar value 71Irwin32 General Discussion (sailing related) 4 01-01-2010 09:43 PM
Value of a Used Yanmar? mrybas Diesel Engine Forum 7 11-17-2009 10:53 AM
Yanmar 2GM zfactor Boat Review and Purchase Forum 5 06-08-2009 10:00 AM
Looking for a Yanmar 2GM knotslo General Discussion (sailing related) 4 03-04-2009 07:12 PM
SEO by vBSEO 3.6.1
