06-24-2011
It is unlikely that you have a crack in the fiberglass glass. Go through all the thru-hulls, close the seacocks. If you have an inboard, check the stuffing box. Check rudder bearing. If you have a water tank, empty it. If you still have leakage, get the boat out of the water as soon as you can and inspect the hull.
1978 Gulfstar 50'
Clark Sailing Dinghy 10'
