  #11
Old 07-08-2011
chef2sail's Avatar
chef2sail will become famous soon enough
We have a harken restrainer. I was able to manuallly take the sail jib sheets off and unwrap the sail not using the drum. I was able to fix the sail lastw eekend. The culprit.....the knot on the other side of the plate which is in the furling drum got extendeded and jammed between the plate and the drub on the bottom inside. I took the bottom part of the furler apart and was able to reset everything except....put the line on backwards so when I furled the sacrificial part was inside out. I ride did it rotating the furling line in the opposite direction
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
  #12
Old 07-08-2011
PalmettoSailor will become famous soon enough
Well at least you didn't make it worse and have to call a rigger. In our case I'm 99% certain the problem was my spinniker halyard. I copied another C36 on our dock by attaching it to the bow pulpit in front of the furler. When I did it, I had the thought that it didn't look like much clearance at the top, but it sure would be convienient and if it worked on another boat, it should be fine on mine, right?
Well it was for a while, but I suspect some of our guest crew may have accidently released the clutch while attempting to adjust the jib halyard tension, allowing some slack in the line. That allowed the spin halyard to get caught in the top swivel which of course happened in the dark.
My major mistake was not taking a minute or three to think through the issue, so I resorted to brute force which is a bad idea on boats and airplanes. Winching the furler twisted the shackle attachment point on the upper swiviel to jam where it wouldn't budge up or down. Fortuately, I did think before resorting to step 2, which is, if force doesn't work, apply more force. That probably saved me having to buy a new extrusion and or upper swivel. As it was, it was only a couple of hours labor for the rigger to remove and replace the attachment strap and put the sail back up.
The big learning point here is you can manually furl (or unfurl) the sail if the roller isn't acting like it should. Just bring the sheets forward and get the thing wrapped up and strap it with some sailties if you have to, then worry about getting the foul cleared when its safe and everything is under control.
BTW, I've gone back to securing the spin halyard to a shroud base so it stays behind and clear of the upper swivel. The boat I had copied was a later model and had a longer crane that put his halyard a couple of inches further forward than on my boat.
PalmettoSailor
s/v Palmetto Moon
1991 Catalina 36
You may post attachments
You may edit your posts
How to Get Aloft to unwrap a double halyard wrap? OldColumbia Gear & Maintenance 16 07-08-2009 12:11 AM
Problem with Halyard Wrap welshwind Gear & Maintenance 4 06-24-2009 04:00 PM
SEO by vBSEO 3.6.1
