Old 06-26-2011
sailak's Avatar
Omega 36
sailak is on a distinguished road
What to clean head/toilet with?
The Admiral is wondering if she could use Polident or Alka-Seltzer to clean the toilet bowl.
What do ya'll use?
Dale
S/V Cirrus
Omega 36
Old 06-26-2011
Tempest is on a distinguished road
soft scrub...
Tempest
Sabre 34
Morgan, NJ
Old 06-26-2011
ToppDogg is on a distinguished road
I agree on the soft scub, off topic question for you Sailak, I checked out your photo gallery and love your Dog, is that a Border Aussie?
Old 06-26-2011
billyruffn's Avatar
billyruffn will become famous soon enough
What are you trying to remove? What’s down stream of the toilet bowl?
If you’re trying to remove the yellow/brown-ish stain/build-up on the head and hoses caused by the combination of urine and sea water, acids work well.
Dilute muriatic acid (hydrochloric acid) is very effective, but must be used with great care and due consideration for the environment you’re pumping it into once it leaves the bowl. Dilute = 4 or 5 parts water to 1 part acid, very carefully pouring the acid into the water. As soon as you pour the mixed solution into the head and pump it into the hoses you’ll notice the chemical reaction -- bubbles, gurgles, etc. In addition to the necessary care in mixing and pouring the acid mixture, you should be aware that muriatic acid has been known to mess up the polymer structure of plastic parts of the head. Multiple cleanings with muriatic acid can cause plastic to become brittle and eventually crack / break. That said, it does work well in getting rid of the build up.
Another much more benign (but less effective) option is white vinegar. Pour a gallon or so into the bowl, let it sit for an hour or so, brush vigorously and pump it out. If the head and hoses have heavy build up the vinegar option may not be up to the task and you may need to clean the head with muriatic acid and replace the hoses.
Old 06-26-2011
deniseO30's Avatar
Lies about her age
the Admirable should use the Captain to clean the head (no that was not a typo )
Old 06-26-2011
Minnewaska will become famous soon enough
Raritan CP only
Jeanneau 54DS
Old 06-26-2011
Soft Scrub works good for me, we have terrible iron stains and it does the trick with a little bit of elbow grease.
Old 06-26-2011
sailak's Avatar
Omega 36
Thanks folks.
ToppDogg - Katie is a Miniature Australian Shepherd. Wonderful dog.
Denise - The Admiral likes you're idea. Gee thanks.
Dale
S/V Cirrus
Omega 36
Old 06-27-2011
SlowButSteady's Avatar
Senior Slacker
SlowButSteady is on a distinguished road
I pour in a half-cup or so of vinegar whenever I leave the boat for more than a day or two (if I remember). I give the pump a 2 or 3 strokes so that there's a bit of vinegar left in the bowl and the hose to work on whatever build-ups are present. Usually, when I open the boat back up, a few quick swipes with the toilet brush and a flush takes care of any residual stains.
Old 06-27-2011
JiffyLube's Avatar
Grasshopper
JiffyLube is on a distinguished road
No doubt muriatic acid will do the job at 5 to 1 (5 parts water to 1 part muriatic), but 10 to 1 would be safer. 10 to 1 is the highest concentration recommended in the ceramic tile trade for acid washing glazed tiles, because higher concentrations can etch the glaze which enables crud to stick better. The porcelain bowl is made much like a porcelain tile, just different in thickness. Brand name vinegar is usually at a 5% strength, which would be about 10 to 1 for muriatic, but even at 5% muriatic is more tenacious than vinegar.
Vacuflush toilet, head. toilets Myblueheaven General Discussion (sailing related) 12 01-25-2012 11:39 PM
Dirty question: do you put toilet paper in the head? legarots General Discussion (sailing related) 36 05-07-2010 01:02 PM
Air Head Composting Toilet arf145 Gear & Maintenance 20 02-07-2010 09:37 AM
What''s the best Head (toilet)..... Myblueheaven Living Aboard 13 04-15-2006 08:45 AM
What''s the best toilet (head) and... Myblueheaven Cruising & Liveaboard Forum 2 10-04-2003 09:52 AM
