-   -   marine hand pump high and dry (http://www.sailnet.com/forums/general-discussion-sailing-related/75735-marine-hand-pump-high-dry.html)
bornagainsailor 06-28-2011 05:30 PM
hi,
marine hand pump not working. new hose last year. before I take it apart, is there anything I can do to troubleshoot.?
thanks
bornagainsailor 06-28-2011 06:16 PM
hand pump clarification
hello again, fyi hand pump in question is a galley, self-priming pump.
sctpc 06-28-2011 06:24 PM
if you havent used it for a longtime it may have dried out inside there is a seal that sucks up the air and water, it it drys out after use ( 1 year + ) it shrinks to flx it get a bottle cut a small hole in the lid put in a straw and squirt water back into the tap end till its full of water then try it again,
this may take several goes to resoak the seal
bornagainsailor 06-28-2011 07:40 PM
thank you. your advice was spot on. much appreciated.
JimsCAL 06-28-2011 08:13 PM
If sptpc's suggestion doesn't get it going, it may need a rebuild (or replacement). Perhaps something could be stuck in the pump valves, so that may make taking it apart worth the effort.
