Rhino Liner on hull for use as barrier coat? - Page 2 - SailNet Community
post #11 of 15 Old 07-15-2011
If it doesn't say "suitable for constant immersion" or something similar, odds are that spending months in contact with water is going to degrade something.
Ask the maker, because that can be an expensive mistake to fix.
hellosailor is offline
post #12 of 15 Old 07-16-2011
I don't think any of those of products are cheap. It cost about $250 in 1999 to cover my pickup bed (8ft) plus sides. A one quart can for "touch up" costs about $15. Plus, as was pointed out above, it has no biocide or algacide. I cannot see how one would benefit. What would be the cost for enough Interlux 2000 to cover a 37 foot full keel boat? Is the the cost savings worth diving about every third or fourth day to clean the hull?
VetMike is offline
post #13 of 15 Old 07-16-2011
T37Chef's Avatar
Originally Posted by ftldiver View Post
anyone use Rhino liner on the hull for a barrier coat?
any problems with Rhino liner for use on marine environments?
The OP asked about using it for a barrier coat, not bottom paint...big difference.
Shawn
T37Chef is online now
post #14 of 15 Old 07-17-2011
xsboats's Avatar
It has been used for years in enginerooms , but I've yet to hear favorable reports of it's use elsewhere.
xsboats is offline
post #15 of 15 Old 07-18-2011 Thread Starter
ftldiver's Avatar
thanks to all!
/thread>
ftldiver is offline
Bottom paint over Gel Coat without Barrier Coat? WagTheDog Gear & Maintenance 17 07-15-2012 08:33 AM
Dry out hull before barrier coat Alacrity36 Gear & Maintenance 21 03-23-2011 02:38 PM
Rhino type liner for deck????? irwin325cc Gear & Maintenance 12 08-30-2009 12:00 AM
Filling holes in hull with epoxy barrier coat slugchewer Gear & Maintenance 12 09-03-2008 12:40 AM
Interior Hull/Cabin Liner Gel Coat Repair SVCarolena Gear & Maintenance 4 12-07-2007 12:20 AM
