Like Tree1Likes
Old 07-19-2011
beanctr56's Avatar
beanctr56 is on a distinguished road
Marking anchor chain
Hi All,
I have an all chain rode and windless. Whats the best way to mark the chain and not get caught in the windless. I was thinking a piece of string every 25'. Whats everyone else do?
Rick
Beneteau 343
Old 07-19-2011
jackdale's Avatar
jackdale will become famous soon enough
Paint works well.
The windlass tends to destroy cords, cable ties, etc..
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
Old 07-19-2011
treilley's Avatar
treilley is on a distinguished road
I use paint. It will wear off the outer surface of the links going through the windlass but the inside of the links stay painted.
Tim R.
Living aboard in Portland, Maine
1997 Caliber 40LRC
and
Old 07-19-2011
SVAuspicious's Avatar
Mermaid Hunter
SVAuspicious is on a distinguished road
I use plastic wire ties (zip-ties). The current set has been on for four years. Three red at 10 meters, three white at 20 meters, three blue at 30 meters, and repeat the pattern at 40, 50, and 60 meters.
sail fast and eat well, dave
S/V Auspicious
AuspiciousWorks.com
beware "cut and paste" sailors.
Old 07-19-2011
ftldiver's Avatar
ftldiver is on a distinguished road
the best solution I've seen is using white paint in dashes long and short. every 20 or 50'
ie, short dashes for every 20' and a long dash and 2 short dashes for 120'
white shows up best...
ymmv.
Old 07-19-2011
lshick is on a distinguished road
Send a message via Skype™ to lshick
I've had good luck with foot-long pieces of 1"-wide webbing, doubled through a link and sewn right next to the link. Red=50', White=100', Blue=150', White=200', Red=250'. Red-white-blue is easy to remember, and the chain can be reversed and the markings still work. A black marker at each intervening 25' point. The original markers have lasted 10 years (6 years of cruising), and I only replaced the markers because I replaced the chain. No problems with jamming or tearing.
landmineop likes this.
Larry Shick
V42-148 "Moira"
Old 07-19-2011
billyruffn's Avatar
billyruffn will become famous soon enough
I have 1/2" wide heavy nylon webbing "tabs" (about 4" long) that are wrapped around and sewn into a link every 25'. I use a magic marker to note the length on each of these nylon tabs. (Yes, I sometimes have to stop the chain and look at the tabs as it goes out, but it's not a bad idea to let the chain out slowly anyway). The stitching has lasted 12 years and the depth notations last about 2 seasons before they need to be refreshed. The tabs have never caught in the windlass.
Old 07-19-2011
jackdale's Avatar
On the underside of the hatch to your anchor use a marker to note the markings on the chain.
Old 07-20-2011
TQA's Avatar
TQA TQA is offline
Bombay Explorer 44
TQA is on a distinguished road
Paint is fine if you only anchor for the odd hour or two.
Anchor for any extended period in sand and the paint will be gone. Plastic ties work for me. But do need replacing say every 6 months but hey takes 5 minutes and costs pennies.
Old 07-20-2011
jrd22's Avatar
Courtney the Dancer
billy- great idea, thanks.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Marking your Anchor Rode for Depth? backcreeksailor Gear & Maintenance 26 11-20-2011 02:43 PM
Anchor Chain TxLnghrn Gear & Maintenance 9 12-24-2008 05:03 PM
Marking Anchor Chain RickBowman Gear & Maintenance 15 11-07-2007 04:15 PM
anchor chain SteveCox Gear & Maintenance 11 07-22-2006 07:39 PM
Marking Chain pblais Gear & Maintenance 10 05-12-2003 08:09 AM
