Like Tree1Likes
Old 07-20-2011
Sublime's Avatar
Quirky
Sublime is on a distinguished road
Lazy jacks
I was curious about what is done to prevent them from interfering with the sail. Or is it a non issue?
I think it'd be a good idea for my boat. I've found videos showing the sail going up and down in them but nothing of what is done with them while under sail.
A ship in harbor is safe, but that's not why ships are built.
My girls:
1974 Alcort Minifish-Minifish
2001 Drascombe Lugger-Penelope
2004 Hunter 260-Miss Muffet
Old 07-20-2011
knothead's Avatar
There are lazy jacks and then there are lazy jacks.
The setup I like has a block on the bottom of the lower spreaders where the "halyard" is reeved and the "drops" are dead ended at eye straps on the bottom of the boom. That allows me to lower and stow the whole system under the sail cover without having to modify the cover.
I also can lower, or not deploy the leeward side if I'm not heading exactly into the wind to prevent the battens from hanging up when I'm raising the sail.
I'm not a big fan of the systems that dead end on the mast and are adjusted at the boom or the ones made with bungee cords.
I usually just ease mine a little when sailing.
Ron Paul 2012
"wikijar"
Old 07-20-2011
CalypsoP35's Avatar
CalypsoP35 is on a distinguished road
My lazy jacks can be released so that they can hooked to the boom where it connects to the mast while sailing. Once this is done the lines run along the boom and the mast with no line interfering with the sails.
Old 07-20-2011
treilley's Avatar
treilley is on a distinguished road
Ditto.
I leave mine out at anchor to prevent slapping the mast. I had my sail cover made to accommodate them. They only get stowed while sailing to prevent chafe on the sail.
Tim R.
Living aboard in Portland, Maine
1997 Caliber 40LRC
and
Old 07-20-2011
T37Chef's Avatar
Senior Culinary Member
T37Chef will become famous soon enough
Try Lazy Jack System - EZ-JAX
Shawn
S/V Windgeist
Tartan 37C #358
Photo by Joe McCary
THE Yacht Builders List:
Useful Food Purchasing Links:
Old 07-20-2011
nickmerc's Avatar
nickmerc is on a distinguished road
You can make your own stowable lazy jacks for about $100 in materials and a few hours of your time. The time includes installation as well. I stow mine when under sail and only deploy them when dropping the main sail.
knothead likes this.
Nick
S/V Blue Bayou
1974 Pearson 30 #517
Old 07-20-2011
chef2sail's Avatar
C&C Racer/ Cruiser
chef2sail is on a distinguished road
I useed to have the Harken system...but installed the EZ jack system the chef refered to about 1 month ago. It is a great system and not very expensive...about 320 dollars so you get 680 change from the BOAT (break out anouther thousand).
The ez jackscks pull back to the mast and under the boom in a 30 second motion when you have lowered the sail and put the cover on. They are not up when raising the sail or while sailing so no chafe or catchoing the battens on them. They take about 20 seconds to deploy each side. Great for single handing as you can put the sailties on back at the dock if you want to.
Dave
___________________________
S/V Haleakula (Hawaiian for" House of the Sun")
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Old 07-21-2011
Omatako's Avatar
Omatako will become famous soon enough
Of course the best lazy-jack solution includes a stac-pac into which the sail stows without any interference from the cords.
Still, it is wise to have the cords operational from the mast as described by Knothead to free the cords off on the leeward side of the sail when under way. Else it tends to rub and chafe and distort sail shape.
Arthur C. Clarke
Old 07-21-2011
TejasSailer is on a distinguished road
I have Ez-Jacks and run shock cord from the top ring to the shroud on each side so that the Ez-Jacks do not interfere with the sail while raising or while sailing and also control the foot of the sail when reefed.
Old 07-21-2011
T37Chef's Avatar
I love this logic!!!
If I could only get the wife to understand it I would be all set
Shawn
S/V Windgeist
Tartan 37C #358
Photo by Joe McCary
EZ Jacks...Lazy Jacks chef2sail General Discussion (sailing related) 13 07-05-2011 02:14 AM
Lazy Jacks/E Z Jacks DLM Gear & Maintenance 1 04-25-2009 04:22 PM
Lazy Jacks GaryHLucas Gear & Maintenance 12 09-17-2008 09:43 PM
lazy jacks dpierce Gear & Maintenance 38 08-18-2006 11:48 AM
Lazy Jacks?? maureena5 Gear & Maintenance 12 11-15-2001 10:29 AM
