07-20-2011
Iroquois MkII
Unscrew the plate, get out all the old sealant (sanding away what you can as well, new sealant against remnants of old sealant can leak), and squish in butyl tape. Push the plate back down, screw it down, scrape off all the butyl tape that squishes out after you tighten down.
The butyl tape doesn't cure - it always remains gooey, so it doesn't dry and crack. It's great stuff, but works best when you are through-bolting hardware (as it is hard to compress otherwise), and oils/gas can dissolve it, so don't use it anywhere below the waterline.
Same deal with your leaky block - pull it off, butyl tape, and replace. If you countersink the bolt-holes a bit, it gives the butyl tape a place to fill in.
You can check out Mainesail's primer on the stuff here:
Bedding Deck Hardware With Bed-It Butyl Tape
