Notes from my log - no advice needed, but I am sure I will get some - Page 2 - SailNet Community
post #11 of 16 Old 07-23-2011
美国华人, 帆船 教授及输送
Originally Posted by Minnewaska View Post
I've sailed all over New England and the northern half of the Chesapeake. There is no area more congested with floating hazards than Maine. None even close.
Note to self: Sailing in Maine. Get a house in Portland ME, retire there.
Fine Print:
I am old school. Integrity is to do the right thing even when no one is watching.
rockDAWG is offline
post #12 of 16 Old 07-23-2011
It's no guarantee against snagging a pot, of course, but I've had pretty good luck with a length of light spectra strung taut between the trailing edge of my keel, and the bottom of my rudder...
I'd suggest anyone sailing in a place like Maine with a split underbody configure such a setup, it's a simple thing to do... Pre-rig it, attaching it to the keel before launch with a pair of snap hooks, so you can just dive on the rudder and clip it on after launch, and the travelift sling is removed...
JonEisberg is offline
post #13 of 16 Old 07-23-2011
The most female moderator
Donna_F's Avatar
Dock
If you see one too late, the best reaction is to go to neutral, not try to take evasive maneuvers.
Thank you. I had not heard this before. I'll add it to my notebook for the future.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #14 of 16 Old 07-24-2011 Thread Starter
old guy :)
rikhall's Avatar
"If you see one too late, the best reaction is to go to neutral, not try to take evasive maneuvers."
Totally - 100%. I should have mentioned that. This is our tenth or eleventh summer down in Maine and for us, just because we see so many and occasionally don't see them, yes - neutral as fast as you can.
So much easier to use the boat hook to push the line past the rudder than to have to "un-braid" very tightly wound line.
Thanks for the reminder.
We had refreshments at Danny Murphy's last evening with Jeff and Karen of Active Captain. Jeff often talks at big boat shows and his topic is often "lobster floats" and how to deal with them. He was saying that what I picked up was probably not visible at all. Many times when they are that close a pair will get "caught" together at low tide and then at high they do not break the surface, but lie in wait to grab the unsuspecting yachtie at about two feet under the surface.
True or not in my case, I do not know, but it made me feel a bit better, anyway.
Shalom all
Rik
Irwin Citation 34
Mystery
rikhall is offline
post #15 of 16 Old 07-24-2011
Rik,
Good job getting off. My "worst" summer for lobsta pot tangling I did it twice. The poly line can get to the point where it not only forms a birds nest around your prop, but also melts in place.
Windy, choppy, foggy, tide running, and 30' long toggles. I've gotten headaches just trying to keep watch in these conditions. You try to figure out which way the toggles are lying, so you can predict which floats are attached by trip lines. But it doesn't always work.
Nevertheless, wishin I was in Maine. Heading up mid/late August
capecodda is offline
post #16 of 16 Old 07-24-2011
davidpm's Avatar
Just to be very explicit. Not only put the motor in neutral but center the helm if you see at the last moment you are going to run over a pot.
The motor in neutral is obvious.
Centering the helm helps with many boat because of their underwater configuration.
When you turn the helm openings between a skeg and rudder or hull and rudder can open up and make it easier to snag a line.
Centered rudder keeps the bottom as streamline as possible and hopefully with shed the line.
davidpm is offline
Advice needed Johnqboater Cruising & Liveaboard Forum 12 02-07-2011 05:24 PM
Advice Needed. Georgiegirl Provisioning 12 07-13-2008 06:32 AM
Help! Advice needed. PalmettoSailor Gear & Maintenance 5 06-25-2008 04:48 AM
Advice needed please seamist2 Boat Review and Purchase Forum 2 11-15-2007 12:04 AM
Advice Needed Please Paddy666 Learning to Sail 3 06-11-2007 10:21 AM
