Like Tree1Likes
  • 1 Post By TohatsuGuru
Old 07-24-2011
Quickstep192 is on a distinguished road
Will a 6HP inboard push my 4000# Quickstep?
My boat originally came with an 8HP 2 stroke motor. That was later replaced with a 4 stroke 8HP. The 4 stroke is much heavier than its 2 stroke predecessor. The motor sits in a well and so can't be tilted up to get it out of the water. At nearly 100 pounds, taking it out after each use is a veritable impossibility. At 60 lbs, a 6HP is much more manageable.
But, will it push the boat against a headwind?
Old 07-24-2011
Michael K is on a distinguished road
A 6 will do the job well enough. As it won't cavitate as much as a transom hung motor the compromise in HP for weight savings is likely worth it. Just be certain to apply antifouling paint to the outboard's leg and prop so as to limit growth and drag. Frankly, I bet most Quicksteps have outboards smaller than an 8.
Old 07-24-2011
dabnis is on a distinguished road
A lot depends on your conditions. I had a Coronado 25, which also had a well, at about 4,500 lbs loaded with a 6HP 2 stroke. It was OK in calm conditions but in my opinion somewhat marginal for San Francisco Bay and outside ocean conditions. Changed to a 15HP 2 stroke, which was the same size and weight as a 9.9HP, and had all the power I could use. A 9.9 HP would have probably been enough? If you re-power suggest you get the longest shaft that will fit and a "high thrust" prop.
Dabnis
Old 07-24-2011
Sublime's Avatar
Quirky
Sublime is on a distinguished road
My boat is 5,000lb displacement and have a 4 stroke 5 hp. It slows a bit with a 20 kt headwind but I've got higher freeboard than you. Still makes decent way.
If you ever move where you have go to against a current, you'll need to bump up.
A ship in harbor is safe, but that's not why ships are built.
My girls:
1974 Alcort Minifish-Minifish
2001 Drascombe Lugger-Penelope
2004 Hunter 260-Miss Muffet
Old 07-24-2011
Flybyknight is on a distinguished road
Depends on the gearing and the prop.
It's all about "thrust"!!
An 8" dia. prop with a 6" pitch
and your 6hp doing wot, you will punch through heavy seas and wind on the nose
with the best of anyone.
Dick
Old 07-24-2011
Cruiser2B's Avatar
Cruiser2B is on a distinguished road
while I have no personal experience, met a couple in Oriental, NC on a 28ft Triton and they were cruising. They used a 6hp Tohatsu. They said it was enough for them on the ICW and sipped fuel. Hope that helps
Old 07-25-2011
Dick
IIRC, at the time I had my boat there were no "sailboat special" outboards with extra long shafts and high thrust props and gearing. I used the largest diameter prop with one inch less pitch than the stock prop. It worked fine, with the 15HP I ran mostly at about 3/4 throttle. Full throttle in high short chop pounded the boat pretty badly so I seldom did that. The important thing is to keep the prop in the water in rough conditions regardless of engine size.
Dabnis
Old 07-26-2011
TohatsuGuru's Avatar
Misanthrope
TohatsuGuru is on a distinguished road
The short answer is no, it is not enough power. That does not mean that it will not push your boat...It will. It just will not have enough thrust in heavy seas or going against a strong current or wind.
dabnis likes this.
Elvin
Solution One Maritime
Old 07-26-2011
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
In the late 1960's we sailed a 26' Thunderbird displacing approximately 3800# out of Sausalito, Ca. Our Aux was a 1962 Evenrude "Angler" 6hp 2-stroke mounted in a well that proved quite adequate for our requirements under all circumstances.
FWIW...
Quickstep 24 Cover? gbaratta Gear & Maintenance 2 08-15-2011 11:48 AM
VHF antenna install on Quickstep 24 dgordon Gear & Maintenance 5 03-31-2011 09:53 AM
Quickstep 24 and Other Boats BlueWaterMD Boat Review and Purchase Forum 2 08-28-2008 08:14 PM
Electric Outboard on Quickstep 24 MJC1968 General Discussion (sailing related) 5 02-18-2008 09:38 AM
Quickstep 24 Arc Boat Review and Purchase Forum 0 04-23-2005 04:42 AM
