07-24-2011
Part of the solution
Your brother is on the money as far as diagnosis. Then once you know what the problem is, you have to fix the problem. I think you're probably going to be pulling the head, which on a Yanmar is no big deal, and check the cylinder walls for scoring, but before that, if the engine will turn over, do a wet and dry compression test. If the crankshaft won't rotate, then you are going to have to yank the head at a minimum.
It's 5 o'clock somewhere:
