07-27-2011
Blue Horizons
Ok how? Basically that boat will be a lot lighter than the same size boat with a lead or iron keel. This means that your boat will be more bobber-like as weather increases. This means that you will be more limited as to when you will be able to sail. Also, your righting ratio will be different. The water ballast is a way for boats to be made cheaper- water is a lot cheaper than lead or iron.
I think you would better off with a lead or iron keeled boat. However, if you are sold on the water ballast then go for it. Just do a little more reading on water ballast boats and how they sail so you know what your getting in to.
