07-28-2011
Heads and Holding Tanks
Okay, so I'll admit that most of what I know about some systems on boats I learned from "This Old Boat" by Don Casey. In it he shows three different configurations for head systems on sailboats. Mine seems to have a third, that doesn't make much sense, is broken and I'm not sure if I should reconfigure.
First there's a holding tank, on one side at the bottom off which there is a bulkhead with a 1 1/2" fitting with flexible pipe that runs to a diaphragm pump (Gusher, I think). Out of that another pipe runs to a Y-valve, one side of which goes up to the deck pumpout fitting, the other side of which goes directly to the thruhull fitting overboard. Sound right to you?
From the toilet, the discharge goes into a 1 1/2" flexible pipe to a vented loop then directly to a bulkhead on the high side of the holding tank.
So when I set the Y-valve to pump overboard (3 miles out to sea) I pulled on the pump handle and got hosed with holding tank fluid (the nice way to say it). Seems there's a problem with the pump, but how to pump out the holding tank from the deck fitting? None of Casey's configurations had the pump between the pump out fitting and the tank. Aaaargh.
