Adding Stanchions and lifelines - Page 2 - SailNet Community
post #11 of 15 Old 09-03-2011
captflood's Avatar
GREETINGS EARTHLINGS; If you go down the jackstay route have two lines from your harness so as you can attach to two points or one line always afixed to the boat when tranfering from point to point remember one hand for the boat and one hand for me ( I use jackstays on my boat) GO SAFE
captflood is offline
post #12 of 15 Old 09-03-2011
johnnyandjebus's Avatar
Originally Posted by rhr1956 View Post
After my recent experience with an unexpected blow and having to douse the headsail very quickly in bouncy conditions...I have to get some lifelines on the boat. After some preliminary online shopping I can see myself spending $1000 pretty easy. I would really like to get the cost down. Any ideas from personal experience would be appreciated.
As all ready mentioned I would rig a downhaul and jack lines first. Both can be done quite cheaply. I sail a contessa 26 with a hank on jib and find the downhaul to be invaluable. As well, having recently installed jack lines I shake my head over the fact that I went so long with out them.
I think that you could install;
- a downhaul for < 100$
- jacklines for < 200$(plus harness and tether)
There may be some minor complications installing the downhaul in your case, in that on my CO26 the downhaul passes thru the base of my stanchions as it works it's way back to the rear of the boat. I am sure this could be over come, you will just give some thought as to how you would route the downhaul line aft if you decide to go this route.
John
johnnyandjebus is offline
post #13 of 15 Old 09-06-2011
L124C's Avatar
As previously posted, our stanchion design does not promote leaks.Dave
Posted where (do you have a link?)?. I'm curious how it works.
L124C is offline
post #14 of 15 Old 09-06-2011
JimsCAL's Avatar
Do you have a bow pulpit? Is so, adding a few stanchions and lifelines is pretty inexpensive. Garhauer makes some nice stuff for a very reasonable price ($65 each with the base).
Garhauer Marine Hardware -3082414
JimsCAL is offline
post #15 of 15 Old 09-06-2011
JimsCAL's Avatar
Dave
Only would work if you have an alloy toerail. The P26 does not. And even then all are not the same. My previous boat (Cal 9.2) had an alloy toerail with the base bolted to the rail BUT also were bolted to the deck through the bottom.
JimsCAL is offline
Stanchions - Yes or No? SailingWebGuy General Discussion (sailing related) 20 01-10-2011 06:55 PM
C&C stanchions Kiltmadoc C & C 6 07-05-2010 06:19 PM
Stanchions tampahokie Gear & Maintenance 2 07-31-2007 12:09 AM
stanchions ddilman General Discussion (sailing related) 3 04-27-2006 01:27 PM
Stanchions RobGallagher Gear & Maintenance 7 11-25-2001 05:09 AM
