08-06-2011
Not familiar with your boat, but I would generally approach it this way:
Raise the mast, and use some method of determining whether it is plumb with the boat. ie. use a halyard or string from the top. You can put a weight on it, and if the boat is level, determine whether the mast is "straight" (might need a little rake to the stern). Tighten forestay.
Then tighten the port/stbd stays in turn until tight. You can check the side-to-side by measuring to the edge of the boat.
Tighten until maybe a few inches of travel when you pull on it. The mast shouldn't move much if at all.
Go sailing. I would think the leeward stay might get slack under medium/heavy winds. If too slack, stop and adjust.
This is very general information. Take it for what it is worth. I don't have a gauge to measure tension when I rig my Catalina 22, but this is my method to get started.
It should get you on the water today, anyway! Go sailing!!!
