08-03-2009
Half Display on screen
I also have that same problem and have just started seriously troubleshooting. I have just found the antenna to be not rotating, Its not jammed, but I can hear gears ratcheting/clicking if I try to help the antenna turn. While turning the antenna by hand, I noted the screen suddenly went to a full circle. I suspect the motor is seized. Any guidance on fixing this issue would be most appreciated.
