Old 08-13-2011
smallboatlover's Avatar
King
smallboatlover is on a distinguished road
flying a spinnaker
so i droped my mast again put the new haylard in for the spinnaker. the sail is brand new never used got it with the boat. so how do i sail this sail? i won't do it by my self. but any tips. with out using a spinnaker pole?
16' mistral sailboat
Old 08-13-2011
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
Without a pole you will only be able to go dead down wind.
With a pole you can actually go a bit to port or stbd. but not that much.
Launch the spinnaker sailing downwind or broad reach using the main sail to blanket the 'kite'.
Once launched don't even think about trying to head up wind until you pull the 'kite' down.
The spinnaker needs constant trimming unlike the main and jib so bring at least 1 person with you.
Good luck.
Old 08-13-2011
Sabreman's Avatar
Sabreman will become famous soon enough
There ere many books on how to properly set up and trim a spinnaker. But online you may try
Spinnaker Setup And Trim – UK-Halsey's Encyclopedia Of Sails
Sabre 38 "Victoria"
Old 08-14-2011
puddinlegs is on a distinguished road
Thanks Sabreman! Young smallboatlover, you need someone to explain google searches for you. Use the force of the internet!
Old 08-14-2011
TQA's Avatar
TQA TQA is offline
Bombay Explorer 44
TQA is on a distinguished road
Good luck.
Is this right ?
I would have thought that assuming you tack one side of the spi to the bow and have the sheet flying free you would need to be running at about 45 degrees to dead down wind to get it to fill.
Old 08-14-2011
genieskip is on a distinguished road
A broad reach is the only thing a cruising spinnaker is good for, which is why I'm getting a spinnaker pole. I find asymmetrical only marginally useful when compared to what you can do with the kite on a pole. And while you can't beat with a kite, if you have one that is cut pretty flat you can carry the apparent wind (slightly) forward of the beam. We did it all the time racing in moderate to light winds and went right by the guys staying with their genny. Of course we carried four or five spinnakers so we could carry a flat cut one. No such luxury on my cruising boat.
genieskip
Northeast
J40
1991
Old 08-14-2011
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
Ah, Well, Not Exactly. We fly our Symetric Spinnaker without a pole using an ATN Tacker with a tack line through a turning block at the bow much like we fly our Asymmetric. Both sails are fitted with ATN socks. The launch and retrieval are a bit of a PITA so we only do this when we've got some distance to cover and winds are light (<10 Knt apparent) but it's quite a workable arrangement.
FWIW...
Old 08-14-2011
King
so i can only fly down wind? i though i could sail it almost all the time? i though i could sail it with the boat even on a close haul
Old 08-14-2011
jackdale's Avatar
jackdale will become famous soon enough
The only spinnakers that sail "upwind" are flat cut gennakers / asymmetricals that will allow a close reach.
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
Old 08-14-2011
CalebD's Avatar
Tartan 27' owner
No. I've been reasonably corrected by others here. You can use the spinnaker to sail across the wind, up to a beam reach or a little further if you are slick. It is going to be harder to do without a pole though.
Your best bet is going to be to get your 16' Mistral out on a light air day and put up the spinnaker and see for yourself. Try going upwind but watch out for getting blown over or broached.
What svHyLyte is suggesting (I believe) is that you can use the spinnaker as if it were a huge jib by attaching/rigging one of the lower corners near the bow. This would be pretty easy if you had a pole.
Flying my spinnaker DwayneSpeer Seamanship 18 07-29-2010 10:03 PM
Flying a Symetrical Spinnaker kwaltersmi Learning to Sail 13 03-10-2009 10:22 PM
Flying an undeclared oversized jib as a spinnaker mikehoyt Racing 4 06-17-2004 04:49 AM
Flying a spinnaker singlehanded jbr Seamanship 2 09-07-2003 07:53 PM
Flying a spinnaker on a dinghy jbr Learning to Sail 0 09-04-2003 08:52 PM
