08-15-2011
SBL,
No offense intended, but it's a little difficult to understand your posts due to the number of misspellings and lack of punctuation. Perhaps you could read the posts over a few times and correct some of that before posting.
I believe that you are trying to run your halyards (lines) aft (back to the cockpit) where you can control them easier. Right?
What you probably would want to do is get some stand up blocks.
Run the lines through the stand up blocks and then to an organizer.
After the organizer, you could run the lines through a rope clutch, or on a boat your size, simple cam cleats would probably work.
You would certainly want to use through bolts and suitable backing plates for these pieces of hardware.
I hope this helps.
Ron Paul 2012
"wikijar"
