08-17-2011
Take it.
My boat was flooded in the same way before I bought it. I replaced both structural bulkheads in two days (one to rip out the old ones, grind off the old tabs, prep the hull, and cut and varnish the new ones, and another day to actually install them). I left the rest of the boat as it was... The wood-cored-fiberglass sole is a bit soft in one area, but not a problem and I'll probably replace it with wood at some point... The other woodwork dried out fine, you can see a waterline on it, but only if you're looking for it...
As far as the engine, I'd just salvage the A4- Pull it out, strip it down, replace what needs replacing, and drop it back in. As long as the block is solid, you can probably have it running great for less than 1k. I know there's a lot of A4 hate out there, but I have no complaints with mine. Starts every time and runs like it should. Any problem with it is pretty easy to fix. Lot of great small diesels out there too, but then you're gonna have to mess around with mounts, alignment, new tank, new prop, etc... You could also just stick a transom mount on the thing and get a cheap 10hp outboard... It's a sailboat after all... Who cares about the motor...
