to motor or not - Page 2 - SailNet Community
post #11 of 18 Old 08-19-2011
Paddle. Save your money. It's a dingy. Don't make it into a keel boat.
puddinlegs is offline
post #12 of 18 Old 08-19-2011
I have had a Honda 2HP for many years. Simple, bullet proof, and the one quart integral tank will take you a long way. I use about a pint trolling and running some for three hours and carry an extra couple of pint cans which I have never had to use. The listed weight is 27 lbs. Might save you a long paddle home someday and much, much easier.
Don't work hard, work smart.
Dabnis
dabnis is offline
post #13 of 18 Old 08-19-2011 Thread Starter
Huck
smallboatlover's Avatar
Ok so i will see if i can get the motor cheap and singe i already got the bracket i should be good. and the thing i was talking about the weight is the weight of the outboard bracket is about 20-39 lbs
16' mistral sailboat, And 27' coronado
smallboatlover is offline
post #14 of 18 Old 08-19-2011
emoney's Avatar
Are you sure about the bracket weighing that much? Sounds like a TON for a bracket. Why not consider a trolling motor which would be so much more effecient and less hassle. If they had a trolling motor big enough to push my 27', I assure you that's what it would have.
emoney is offline
post #15 of 18 Old 08-19-2011 Thread Starter
Huck
well the bracket holds up to a 15 hp
post #16 of 18 Old 08-19-2011
A trolling motor weighs about 15 to 20 lbs, a group 27 battery about60 to 70 lbs, then where do you put the battery and how do you keep it charged? A "smart" charger costs about $75 to $100 and should be on almost all the time. Just a thought?
Dabnis
dabnis is offline
post #17 of 18 Old 08-19-2011
tommays's Avatar
I think if google a tiny bit you will find FAR BETTER SUITED mounts
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #18 of 18 Old 08-19-2011 Thread Starter
Huck
ya but the thing is with my boat it heels a lot and i have to hike. so raising the motor out of the water is what i need i don't want the motor draging making the boat slower by a lot. i have a swing bracket right now. It should get it out of the water
what should i do for a motor smallboatlover General Discussion (sailing related) 9 05-24-2011 09:47 PM
What motor is this? cpd304 Gear & Maintenance 2 03-03-2011 07:12 PM
Too much motor for a 17? sealover General Discussion (sailing related) 9 12-24-2010 01:38 PM
Is a 15 hp motor too big for CAL 25? sailguy40 Cal 11 05-16-2010 05:49 AM
getting a motor for 14'' sklamar General Discussion (sailing related) 1 07-24-2002 02:56 PM
