Solo sailing hard lessons - Page 2 - SailNet Community
 2Likes
post #11 of 13 Old 08-22-2011
casey1999's Avatar
Good to hear all ended well mate. Nice yacht you have- she looks strong and brave- and was!
I think I will pick up that 3 gallon fuel container and rig it for an emergency fuel supply- with a direct gravity fed fuel line to the injection pump (somthing I have been thinking about). And stock the boat up with some coffee- don't drink the stuff but I would if I need to stay up 36 hours.
Aloha
casey1999 is online now
post #12 of 13 Old 08-22-2011
Chastened
Ajax_MD's Avatar
Originally Posted by Thestar View Post
Hi I would love to post the track I have a slight issue I am a bit confused on how to export it.
I use a Garmin hand held H72 then interface it with my laptop to OpenCPN.
How do I export the track there does not seem to be an option?
Garmin H72 only holds 10 tracks and has options SAVE/CLEAR main window, menu window has options: Setup Track Log - Delete Saved Track - Delete All Saved.
I have a digital manual on the device if that would help?
I have the exact same model. You cannot directly import the track file into OpenCPN. Download a cheezy, free program called "EasyGPS". This program will interface with the Garmin, and extract the file. It is a .gpx file. Then, you can import the .gpx file into OpenCPN and it will overlay it onto a chart.
In EasyGPS, you'll need to set the COMM port that you're using (usually 3 or 4), and make sure that both EasyGPS and the Garmin are speaking the same language. (Garmin or NMEA)
Not sure if you know this, but if you have a newer laptop that does't have an old serial port, you'll need a serial-to-USB converter. (It just looks like an adapter plug)
1981 Tartan 33 #168
Ajax_MD is offline
post #13 of 13 Old 08-22-2011
Cruiser2B's Avatar
Intense story, always prepared for the worst! Looks like you have a seaworthy vessel and great captain! Good Job Capt.!
Cruiser2B is offline
Lessons learned the hard way ClaireFAISE General Discussion (sailing related) 5 09-27-2010 08:26 AM
Sailing: Solo sailing hero MacArthur hopes to put Asia on the map (Channel NewsAsia) NewsReader News Feeds 0 05-11-2006 01:15 AM
Clevland, OH Sailing Schools or sailing lessons reccomended Jtyler Learning to Sail 0 06-24-2004 08:04 AM
Sailing Lessons Mark Matthews Learning to Sail Articles 0 07-30-2001 09:00 PM
Hard Lessons Relearned Dan Dickison Racing Articles 0 07-22-2001 09:00 PM
