Old 08-22-2011
Quickstep192 is on a distinguished road
StarBoard for Motor Mount?
My sailboat has an outboard in a well. The motor is mounted on a piece of teak about 18" wide and about 10" high. I'd like to have less teak on the boat, so I'm thinking about replacing it with something synthetic. Also, I've heard stories of the teak mount snapping across the grain, so just more motivation. The teak mount is a piece about 7/8" thick that spans the width, then another piece across the back where the motor mounts that makes it 1/34" thick in the middle. If I made the same thing out of Starboard, would it be strong enough?
Old 08-22-2011
Irrationally Exuberant
arf145 is on a distinguished road
I wouldn't trust Starboard for that. Look at FRP, like this from McMaster-Carr
arf145
1987 Pearson 28-2
Chesapeake Bay
Old 08-22-2011
emoney's Avatar
emoney is on a distinguished road
Might be easier to just glass a board...stronger too.
Old 08-22-2011
dacap06 is on a distinguished road
Send a message via Yahoo to dacap06
The short answer is no, Starboard won't hold up. I'm with emoney on this one. Either glass it or coat the board with epoxy to prevent rot and then paint it so the epoxy is not exposed to UV.
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
Old 08-22-2011
fryewe is on a distinguished road
Laminate teak/okume plywood together using resorcinol glue to the thickness needed. Soak the edges with epoxy and glass over them with a layer of 4 or 6 oz fiberglass cloth. Then glass the whole thing. When it's dry, paint it. Install it using liberal amounts of dolfinite in the screw/bolt holes.
Starboard is not a structural material. It will not do for this job.
i need to add a motor mount...how hard is it? mountforever Gear & Maintenance 6 07-09-2009 11:10 AM
4 stroke motor mount cal30 Gear & Maintenance 4 03-03-2009 01:46 PM
Motor Mount Replacement? kipwrite Gear & Maintenance 6 07-03-2008 11:44 AM
Bent Motor Mount brrit Gear & Maintenance 1 11-12-2007 09:47 AM
motor mount help hubbardsw Gear & Maintenance 1 11-12-2007 08:07 AM
