Old 08-27-2011
arknoah's Avatar
s/v Ilya
arknoah is on a distinguished road
How's Your Boat Faring so Far?
Well, I went to the marina (West Basin at the Patuxent River Naval Air Station) just now to check on the boat. Things are basically okay, though I should have made my bow lines even tighter, as the boat is being pushed pretty hard toward the dock, and the starboard side is pushing against a specific area of the pier. The good news is that spot on the pier is the one with the most fenders which are doing their job. Also, I discovered that the outboard propeller blades had chewed into the dock a bit. Many other people had untilted their outboards in anticipation of this. While the engines are still lifted from the fully engaged position, they aren’t tipped. I decided to follow suit so I don’t want to have a completely compromised propeller. I’ll check on it again tomorrow morning with the light unless I have another reason to go out this evening.
Of course, while I was out there I got soaked to my underwear….
Ilya's Adventures:
____________________________
And straight on 'til morning
Old 08-27-2011
MarioG's Avatar
MarioG is on a distinguished road
The storm has passed us and our boat is fine. I stripped it down prior and had a dozen lines holding to a floating dock.
There was one 25' power boat that sank.
Old 08-27-2011
AirborneSF is on a distinguished road
Thumbs up
Not sure, I'm going to the Rec center soon to recheck things. Yesterday I adjusted the lines on "SOLACE" with as much slack as I felt comfortable with, and still not touch any of the dock. Post more after I get back.
Old 08-28-2011
BubbleheadMd's Avatar
Chastened
BubbleheadMd will become famous soon enough
Send a message via Yahoo to BubbleheadMd
All boats at my community dock did fine. We checked on them all night. The lack of any appreciable storm surge was a huge help.
I gotta say, the new Pearson is awesome. The only leak was from a worn seal on the window in the head and it took 12 hours of driving rain to expose it.
S/V Old Shoes
1973 Pearson 30 #255
Old 08-28-2011
chef2sail's Avatar
C&C Racer/ Cruiser
chef2sail is on a distinguished road
We received reports that Haleakula fared the storm fine. Having a slip which is 63X 16 for a 35ft boat gave her plenty of room to move about and plety of line lenghth to play with. Next item to buy...snubbers.
My prayers are with the friends we have made in New England the the LI Sound.
Dave
S/V Haleakula (Hawaiian for" House of the Sun")
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Old 08-28-2011
jimrafford's Avatar
jimrafford is on a distinguished road
Just got back from checking on the boat. The docks came 4" from coming off the pilings. Way too close. We had no damage but a couple other boats had some minor issues. Deffinatly dodged the bullet on this one. Trees blocking roads making travel difficult. Power is out everywhere. Last report I heard more than half the state is w/o power. Going to be a long week.
Jim
S/V Deja Vu
CS 40
Old 08-28-2011
dacap06 is on a distinguished road
Send a message via Yahoo to dacap06
I went up to Pasadena to take a look at Tranquillity Base and move it so it only occupies it own slip (I'd moved it to the middle of the double-wide slip when my slip neighbors were hauled, and then left the dock lines a little looser than normal in case of surge). I had 11 lines rigged -- 5 to cleats and 6 to pilings.
Getting into White Rocks marina was rather interesting. The utility pole at the entrance to the marina broke and fell to a leaning position, and power lines are on the ground. They are primaries (30 KV), and power was clearly secured, but that doesn't mean they are dead. They could have lower voltage -- essentially leakage -- for a number of reasons. I parked a block away and walked in (against the advice of the BG&E folks). The advantage of being an Electrical Engineer is that I know the risk of being around the lines and how to avoid trouble.
TB suffered no damage, although it was a little wet inside. All 11 lines held, although one of the bow lines and its chafing gear is looking a little careworn. Time to replace it. The initial NE winds pushed the cabin roof hatch open a little. I'm glad I had the hasp and lock on it so it couldn't move very much. Still, there was enough movement to create a slot for the rain to get in. It must have been raining nearly horizontally -- the port settee is damp over most of its length and There was still a little water on the cabin sole near the hatch and entryway steps as well as dampness in the galley sink. I mopped the water. The rest will dry in time.
I got to the marina about 12:30, about an hour before low tide. I timed it in case of flooding in Rock Creek and the Patapsco River. The timing turned out to be a needless precaution as the water level was unusually low. The NW winds were blowing all the water across to the east side of the Chesapeake and almost a foot of barnacles were exposed on the pilings. The winds are stlll pretty stiff. I'd guess it was blowing between 25 and 30 kts between the time I arrived and the time I departed at 3 PM.
I'm happy. Overall, the blow could have been much worse and my preparations were sufficient. Besides, I can now conclusively say that the portlights I replaced earlier this year do not leak! There were no water marks on the wood trailing down below them.
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
Old 08-28-2011
Minnewaska will become famous soon enough
So far, the Quonset Point weather station in Narragansett Bay shows max sustained winds only in the 40s, with peaks above 50, although that range lasted for hours. Max surge was 3 ft, but that was nearly three hours after high tide, so that may have been on the bubble with the lower parking lot. Should not have been a threat to the yard. Power is out all over Rhode Island with no published recovery time yet.
I took off to refuge about 300 miles away, so I've had to follow it all vicariously on the internet. Next time I need a web cam to watch the boat !!
Anyway, it seems the worst would have been from wind blown debris, so I'm hopeful we've made it okay. Probably won't know for a couple more days. I'm mentally prepared to return to a cockpit full of leaves and debris, but that would be a blessing.
Jeanneau 54DS
Old 08-29-2011
arknoah's Avatar
s/v Ilya
I was able to check on Ilya Sunday, but couldn't get to the internet until today as our power has been off since 7:50 pm Saturday night (it's 7:55 am Monday now). Everything seems fine, though I didn't check too carefully down below. Two or three boats at our marina have shredded jennys, and one boat managed to go from B dock all the way past D and crash on the shore. Can't figure out how that happened.
While there seemed to be some damage to rub rails, most people seem to have done pretty well.
Ilya's Adventures:
Old 08-29-2011
Not just a member
motovationcycles is on a distinguished road
southern MD
Spent the night on my boat at Placid Harbor back behind Myrtle Point. I had removed the genoa as well as the dodger. I lashed down the main and dodger frame. Added extra lines. Went out several times overnight to check boats around the marina. It was good to see all the work I have done pay off. Not one freshwater leak! My wife texted me to let me know we had 3 trees fall on our house. Took me 1.5 hours to drive the .25 hour to my house. The storm was over but still light rain. I towed 2 cars stalled in high water. House is not leaking but 3 trees are on the back roof. Waiting on tree service. Power came on about 1600. Could have been worse.
Dan
"Wind Wing"
Piewiet 850 / Dutch Flyer 28
Solomons, MD
Chesapeake Bay
"For the truth is that I already know as much about my fate as I need to know. The day will come when I will die. So the only matter of consequence before me is what I do with my allotted time. I can remain on shore, paralyzed with fear, or I can raise my sails and dip and soar with the breeze."
Richard Bode
-- from First You Have to Row a Little Boat
For Sale - How's this sound? campbdon Boat Review and Purchase Forum 23 02-18-2009 12:33 AM
C2, how's the fishing? xort Off Topic 46 01-18-2009 08:30 PM
How's this for an insult Johnrb Off Topic 30 04-30-2008 04:07 PM
how's the water gestapo these days? distantdrummer Cruising & Liveaboard Forum 11 07-17-2007 08:25 PM
How's my tack? RayMetz100 Learning to Sail 14 12-14-2006 12:29 PM
