- Quick Menu
2Likes
08-30-2011
Genoa on Hanse 42
Just fitted new 150 genoa but cannot get the foot parallel with the deck when close hauled, even when the block is set as far aft as the track will allow. As a result, the leach is not fully taught and vibrates, which will shorten its life. The sail was custom made for the boat specs, so should be ok. Any suggestions for a solution?
08-30-2011
The foot does not need to be parallel to the deck. Move the block forward till you get good results with the leach.
08-30-2011
genoa rig
many thanks for swift help. Will try that on friday. Makes sense as the foot would then be just clear of base of upper shroud and the sheet would be pulling directly down, instead of at an angle. Will let you know result
08-30-2011
The angle of the sheet from block to clew should form an imaginary line that roughly bisects the luff (leading edge) of the sail. From that point you move the block slightly forward or aft so that when you do luff up, all the telltales 'break' at the same time. If the uppers break first, the block should go forward, if the lowers, then tweak it aft.
In heavier winds run the block further aft than ideal to spill a bit of power and open up the slot somewhat.
1984 Fast/Nicholson 345
08-30-2011
"IF" the sail sail leech still vibrates after you have the sheet set so it lines up with the mid point of the luff as faster points out, you would need to tighten the leech line some. Which is a very light line that should be on the foot, and leech, about kite string thickness to a bit thicker, 1/8"/1-2mm at most.
I took my HS's and layed them on the ground, found the midpoint of the luff, took a line of some sort, might have even been the tape measure I was using to the clew, literally drew a line with a sharpie from the clew 2' or so on this line. This give me/crew a quick visual if the carrs are set correct. If you have an RF, this is really important, because as you roll the HS in, the carr needs to move forward. Having a line control carr fromt eh cockpit is REALLY handy, then no one needs to mover forward to adjust the carr using the pin.
Marty
She drives me boat,
I drives me dinghy!
08-30-2011
I don't discuss my member
You got a custom #1 for a 42' boat and the sailmaker couldn't go on a ride with you? Did he have a main to build for a TP52 or something more important than taking care of a paid customer?
Get the sailmaker out for a sail with you. It's his job to check his work, and get you tuned in.
Merit 25 # 764 "Audrey"
08-30-2011
Do this sooner than later too. I got a new 155 string style from a local loft, stuck it on, he did not come out initially, then another person from YC said the genoa did not look right. thought about it, and said, self, he could be right as my 140 pulls better than the 155 some times.....so out he came, turned out there was a slight problem when made, got it shaped a bit, and we are now WAY faster, and the sail is pulling as I thought/felt it should.
having them out can be a help too!
Marty
She drives me boat,
I drives me dinghy!
08-30-2011
Jenny wrench
Many thanks, guys!
In my mind's eye, the sheet points to a point lower than the midpoint of the luff, so moving the block forward should improve this, bearing in mind the main objective is to trim the the leach, as the genoa drives the boat at 11 knots in a force 5 five without the main and very smoothly too.
We made a videoclip to send to the sailmaker. It never occurred to us to invite the sailmaker to come along. Too trusting?
Consdered trimming the leach line, after all, that's what it's for, butsurely not when it's a new sail, or maybe that's exactly what you should do. I thought maybe shake out the creases and give it a bit of breaking in first would be wise.
09-04-2011
genoa reefing
We moved the block forward 1 hole, (6 inches) which helped, and then tightened the leach a few inches, which stopped the vibration. Then moved the block forward another hole, which was even better, as the clew could be pulled closer to the deck and the middle of the foot was less inclined to go over the rail. On a couple of occasions, we even managed to prevent it going over at all, so, yes practice, timing and speed with hauling in the sheet are now the key. So many thanks again for the sound advice.
Having got that problem fairly well sorted, we encountered another problem. When the wind speed increased, we reefed the genoa, but the jamb on the block used to control the roller reefing line couldn't take the strain, so we had no choice but to furl the sail completely. There was talk about needing 2 winches in addition to the 4 we have, which would be nice, but at £800 each, plus fitting...?
I don't think we need them, anyway. We just need something on 1 side only to hold the the roller reefing line securely in place when reefed. Suggestions very welcome!
09-06-2011
I don't think you need another winch. Try sailing deep or head up into the wind to furl the genoa.
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Hanse Yachts
MooreVOLS |
Boat Review and Purchase Forum |
5 |
11-25-2010 12:18 AM |
Hanse
stm |
7 |
02-08-2008 08:09 PM |
Hanse
Alden68 |
26 |
06-27-2007 02:13 PM |
Hanse 37
LarryLevine |
1 |
09-29-2002 05:56 PM |
HANSE
LarryLevine |
8 |
07-09-2002 11:30 AM |
