Old 08-30-2011
CraigCS27's Avatar
Lake Pirate
CraigCS27 is on a distinguished road
Thumbs down Ripped Sail along Seam Question
Hi all,
I have a rip along the stitching on my front sail. I was wondering if this is something that I can repair myself, or if I should take it in to the pros to fix. It's only about 6" long...I should have taken a picture, I will try to get one and add it to this thread tonight.
CS 27 #1644
Old 08-30-2011
Minnewaska will become famous soon enough
If it's just the stitching that came loose, then I would stitch it back up. If it has a tear through the material, I prefer to have a pro make it look as nice as possible. Although, if you didn't do that in winds far greater than the sail should be flown in, it is a sign of things to come.
Jeanneau 54DS
Old 08-30-2011
celenoglu's Avatar
celenoglu is on a distinguished road
This is not a big repair, you can so it yourself. Hand stitching is far superior to machine sewing.
the place of the rip is important. If it is due to wear of the stich (maybe due to sun), it is better to get proffesional help. Otherwise the rip might appear in other places.
Old 08-30-2011
CraigCS27's Avatar
Lake Pirate
Ok, good info guys....thanks a lot!
I think I'll try to fix this myself, and then if I need to do it again...I'll take it to Boston Doyle in Sarnia, Ontario.
For now, I've just winched the cable halyard tight, and I'll use the second halyard to haul up another front sail that I have....the other sails I have are hank on...the sail that's ripped is set up for furling. (Zip Cord I think it's called?)
CS 27 #1644
Ripped Main Sail Flybyknight Gear & Maintenance 2 06-18-2010 08:25 PM
Keel pocket seam recommendations needed. fparry SailNet FAQ's 3 02-26-2010 01:23 PM
Ripped my main sail SSBN506 Gear & Maintenance 15 08-27-2008 09:19 AM
Bowsprit Ripped Off!? Kacper General Discussion (sailing related) 29 05-02-2007 07:42 AM
RIB Repair on the seam dsbentley Gear & Maintenance 1 03-15-2007 09:34 PM
