08-30-2011
Ok,
The secret is:
Use MEK (Methyl Ethyl Ketone) it is the solvent to clean and prep the PVC.
When applying "glue" (NRS uses LA4123 from Cliffton Adhesives, Inc.) Put thin layer on both patch and boat, let dry. 20 min. or so.
not a typo.
Now that you have done the 2 coats, put last coat on and wait till almost dry, say 15 to 18 min. Now apply together using any tool that will mush the two parts together, as said before.
The thought is, not to trap the VOC/fumes in "glue" or the reaction of the PVC and "glue" between patch and boat.
I say this because I have a PVC and a Urethane 13' white water raft. I have glued in some extra D rings and that's how I was told to do it. Never had a hole in one so far.
Hope that helps,
Catalina 25 1984 #4558 Swing Keel, Tall Rig
Sailing Payette Lake, Central Idaho USA
_______________________________________________
