Like Tree1Likes
Old 08-31-2011
swillyboy is on a distinguished road
over heating engine
i have a benateau 361 with a over heating problem after an hour of motoring the alarm sounds i turn off engine and find i have lost coolant. i have removed the heat exchanger and cleaned it but the same thing happened next time out. i do'nt think it is the stat or pump any ideas.
Old 08-31-2011
erps's Avatar
the pointy end is the bow
I"ve experienced a few overheats and each has either been an obstruction to the raw water circuit (sea strainer and before) or worn raw water pump impellers. That's where I would start.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Old 08-31-2011
Another good candidate for obstructions is at the mixing elbow-where the RWC enters the exhaust system.
However if you're losing coolant - do you see/smell a leak? If the coolant is disappearing without evidence of leakage you may be burning it or losing it to the RWC side (though generally the RWC ought to run higher pressure than FWC). Do you see any evidence of whitish 'smoke' that might indicate you're burning it?
1984 Fast/Nicholson 345
Old 08-31-2011
jackdale's Avatar
jackdale will become famous soon enough
Head gasket?
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
Old 08-31-2011
captflood is on a distinguished road
GREETINGS EARTHLINGS; Have you checked that the pipes are free from kinks or are not blocked with debry or silts pipe cleaning types of bottle cleaning brushes checking all bends and juntions are clear . GO SAFE
Old 08-31-2011
Tempest is on a distinguished road
Do you have coolant in your bilge after shutting down? No sign of leaks? Good water flow out the stern?
Is that Londonderry, Ireland??
Tempest
Sabre 34
Morgan, NJ
Old 08-31-2011
HDChopper's Avatar
Needing Apehanger Helm
HDChopper is on a distinguished road
Check your oil & make shure it didnt turn to milk.
Semloh likes this.
There is no right way to do the wrong thing
Old 08-31-2011
Semloh is on a distinguished road
Heat
1 hour is a long time.
I would think that you are losing coolant then getting hot.
Cracked Head, Blown head gasket.
If you are losing it into the cylinders you can sometimes get a faint coolant smell in your exhaust and most likely your oil will change to a milky color.
Old 09-01-2011
over heating
all lost coolant has ended up below engine in bilge i have cleaned elbo also cant find any holes plenty of sea water pumping out a stern no milky oil still at a loss, could it be a faulty circulating pump ?
Old 09-01-2011
HDChopper's Avatar
set it all up for a run, then watch the eng compartment while you run it for an hour or so sounds like the leak / pinhole only gets going once pressure builds up , if all coolent is in bilge .
Of course if eng even seems to get hurt shut down...
Sounds like a bad clamp / bad fitting / valve / pinhole in anything , keep eye on pump , pump bearings take pressure to leak there should be a weep hole some where on the pump around the pump bearing ( well just about all coolent pumps do)...
Reverse air not heating well LakePirate Gear & Maintenance 12 03-15-2010 11:03 AM
heating and conditioning ustunkal Living Aboard 5 07-13-2006 03:09 PM
Over heating Diesel Captnbn General Discussion (sailing related) 8 03-20-2006 10:52 PM
volvo engine heating up brpfs Gear & Maintenance 2 07-28-2003 01:00 PM
Heating Question pirateofcapeann Living Aboard 3 12-14-2002 02:12 PM
