Old 09-06-2011
cb32863's Avatar
Boat Owner
cb32863 is on a distinguished road
Question Centerboard Sailors
A question for you folks that have a centerboard or have sailed with one. Do you adjust it as you sail or do you pretty much lower it down and forget about it?
Umquam Porro
S/V Papillon 1977 O' Day 25
Old 09-06-2011
saillife is on a distinguished road
Drop it and forget about it until/unless it hits bottom...... Now if you're racing you'd want to raise it on your downwind run.
Old 09-06-2011
OtterGreen's Avatar
OtterGreen is on a distinguished road
on my Santana i usually leave it down unless i know it is shallow. i prefer not to let it drag if possible. inside the channel i will leave it down until i hit the shallows, or when going downwind i will leave it at about a foot.
Old 09-06-2011
whroeder's Avatar
whroeder is on a distinguished road
The angle of the board moves the center of effort, down too much gives too much weather helm.
If you have too much, turn into the wind and adjust.
On my Mac26X My rudders run start dragging before the CB does.
Old 09-06-2011
chef2sail's Avatar
C&C Racer/ Cruiser
chef2sail is on a distinguished road
Drop it on close haul all the way to broad reach, especially when the wind is over 15. Raise it broad reach to run.
Dave
___________________________
S/V Haleakula (Hawaiian for" House of the Sun")
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Old 09-06-2011
5hortBu5's Avatar
5hortBu5 is on a distinguished road
Depends on my attitude and mission that day. If I'm just mucking about in a boat, especially solo, I'll set it around halfway and just forget about it. If I'm trying to get somewhere, or playing with sail trim or have a couple extra hands aboard, I'll adjust based on my point of sail. Down for beating, halfway for reaches, and up for dead runs.
Old 09-06-2011
Tweegs is on a distinguished road
We’ve found that it is a lesson in physics.
Drag vs. lift.
Here is the short of it:
Say you’re on a beat in a stiff wind. Generally, you’re heeled over fairly well.
Since our CB weighs only 100 to 200 lbs, the added length of the board really does nothing to help keep the boat on its feet, rather it generates lift in the wrong direction heeling you over further.
So why use a center board at all? To help keep the boat from slipping.
By lowering the CB you increase lateral resistance, but you also increase drag and induce lift.
We’re still playing with optimal settings under given wind speeds and boat headings, but our starting points are:
Half down on a reach.
One quarter down on a beat.
Full up on a run.
And we’ll adjust from there based on boat heading vs. course over ground as read on the GPS.
All of this is as it was explained to me by my egg-head, math wiz, jib trimmer.
Help! Centerboard won't go up! needsanap General Discussion (sailing related) 5 08-19-2011 07:41 AM
Centerboard niktash Mariner 1 05-25-2009 01:24 PM
Re: Connecting Sailors to Sailboats / or Sailors to Sailors NewsReader Mass Bay Sailors 0 05-25-2007 12:15 AM
O''Day 25 centerboard Jocelyn(Nipan2) Gear & Maintenance 1 01-22-2005 09:17 PM
