Old 09-13-2011
Hardysea is on a distinguished road
EU - US electrical system conversion
I'm considering buying a used '04 DuFour 37 which was in the UK, and has all European electrical systems. Does anyone know if I will be able to run my US stuff on this boat? It's got a 12V and 230V system. How much do you think it will cost to change everything over to US standard 110V? Will this boat be able to use local shore power, or will it have to rely on it's engine to recharge? Any thoughts or info would be appreciated!
Old 09-13-2011
hellosailor's Avatar
The 12vdc equipment will work fine as is.
You have three options on the 230VAC side:
1- Install a 120VDC:230VDC transformer, so you can take US dockside power and feed it to the boat and any 230VAC equipment on the boat. That's cheap--but ou won't be able to sue US AC devices without further adapters.
2- See if the charger/inverter can be switched to 120VAC. If it can, keep it, rewire the rest of your sockets direct for 120VAC.
3- Scrap the AC stuff, get a 120VDC charger/inverter, and live off DC.
The best solution will really depend on what you can junk/convert/save and you are probably best off waiting till you get hands on eyes on all of it to find out just what's on the boat. Not what the boat was supposedly built with, but what's really on it now, and how well that suits your needs.
Tags
charging system , electric , european , shore power , wiring
Help With New Electrical System Oldsoul Electrical Systems 44 02-03-2012 10:09 AM
Conversion from In-Mast furling to Lazy-Jacks system possible? freeheel999 Gear & Maintenance 21 09-14-2009 10:17 AM
3 wire electrical system? Islander30Bahama Electrical Systems 2 02-17-2009 11:28 AM
Electrical System Trouble RogerHardman Gear & Maintenance 0 05-28-2006 07:33 PM
Electrical System Ground Tracuman Gear & Maintenance 10 05-09-2006 05:45 PM
