09-14-2011
Old as Dirt!
Originally Posted by captbaja
Looking for for some advice regarding water heaters. I have a 6 gallon Raitan water heater that is a least 10 yrs. old. It is now leaking. My first thought is to replace it with the same Raritan heater, (or as close to it is they now make). But have statred to wonder if there could be a better solution. We live on our Columbia 45, so of course it gets a lot of use. A galley, 2 heads one with a shower, that two of use daily. The space the heater is in is really tight and hard to get to. I would like to put in a larger heater but don't know if that is possible. I would also like to get a heater less expensive than the Raritan, but not one I will need to replace again in a few years. I have wondered about flash heaters at each location, any ideas, knowledge or experiance. thanks
Frankly, 10 years is not very much for a Raritan. Are you certain your leakage is from the tank and not a fitting? Rusting of the cover around the base is not necessarily an indicator of leakage there. Never-the-less, if you do have to replace the unit, and choose a Raritan again, be sure to service the Anode to ensure a long trouble free life (see Raritan 1700 Series HW Heater - Cruisers & Sailing Forums).
FWIW...
