09-13-2011
Frozen fasteners can be a real headache.
If you are willing to sacrifice the traveler, then you can use a cut-off wheel or a hacksaw to attack the frozen fasteners, it will make a real mess of things, but if you plan to replace it all, who cares?
Otherwise, go back to soaking with penetrating oil and waiting. Then try the impact driver again. There is a technique to using those tools successfully. You need twist them slightly as you hold them to pre-load the driver before striking it. If it is deforming the driver bit, then use a larger bit. Using the largest bit already? Then perhaps you aren't using enough colorful language, let those bolts know who they are dealing with.
Good Luck!
