Old 09-20-2011
bobber is on a distinguished road
Speaker hole in cockpit: what to do?
This 27 foot sailboat has a speaker mounted low in the cockpit. For better seaworthiness, I think the speaker should be removed and the hole sealed. Any recommendations?? Or would you leave it like it is? The boat will be sailed in San Francisco Bay.
Speaker hole in cockpit:  what to do?-speaker-sailboat-cockpit.jpg
Old 09-20-2011
chrisncate's Avatar
Mango intolerant
chrisncate is on a distinguished road
Fill and fair it out. West system thickened with 407 over a wood plug coated in glass and epoxy.
Imo.
Old 09-20-2011
Hartley18's Avatar
Termite Fodder
Hartley18 will become famous soon enough Hartley18 will become famous soon enough
What CnC says.. The glass and epoxy goes on top.
This should help you get started: http://www.sailnet.com/forums/gear-m...tml#post736826
Crew member on the Womboat for:
2011 Heaven Can Wait 24Hr - Race against Cancer.
Old 09-20-2011
PaulinVictoria's Avatar
PaulinVictoria is on a distinguished road
It looks a bit weedy, you need at least a 12" sub with around 500w powering it.
To err is human. To arrr is pirate.
S/V Tangerine, 1979 C&C24
Old 09-20-2011
Minnewaska will become famous soon enough
Personally, I would not worry in the slightest about its impact on seaworthiness. If I was, it would be much easier to fashion a cover over it, than to repair the hole.
Jeanneau 54DS
Old 09-20-2011
H and E is on a distinguished road
If it were me, I would make a wood or plastic cover. Mount it with silicone or other water proof adhesive. Decorate it to your taste or paint to match. Making a fiberglass repair will be a lot of work and unless expertly done may not look very good.
Old 09-20-2011
lans0012's Avatar
Daysailor wannabe cruiser
lans0012 is on a distinguished road
Starboard option
I have speakeres mounted like that in my Cal 27 and I don't worry about the seaworthyness aspect. The speakers could let water in if your entire cockpit was flooded. If you are planning an offshore passage maybe you should cut out some 6-7" squares of Starboard, remove the speakers and screw in and seal the starboard. You might even be able to use the same holes for the speakers. Keep the speakers so that you can put them back in later.
I mostly sail in Tampa Bay and one day coastal hops. So I'm not concerned. If I was going to cross the gulf or something I would take them out and screw in the starboard sections. It'll probably cost you about $20 for the starboard and take all of 5 minutes to install once you have them cut. It will look good too and not require painting. You could glue a rubber gasket around the starboard and you would be all dialed in.
Old 09-20-2011
Sail the boat a while and see how often you actually fill the cockpit.... then you'll know if it's really going to be much of a problem.
I reckon there are thousands of boats out there similarly set up....
1984 Fast/Nicholson 345
Old 09-20-2011
apogee1mars's Avatar
apogee1mars is on a distinguished road
Mount the speakers on the INSIDE of the holes. That way the outside surface is flush for screwing in a butch plate if you go to weather. Get some better speakers, the damage is done.
Old 09-20-2011
JonEisberg will become famous soon enough
Is the speaker still in use, or would you prefer to keep that option?
A quick and easy method would be to find an appropriately sized screw-in deck plate, like those from Beckson...
For an offshore boat, that's the ideal method for installing cockpit speakers, anyway - recessed behind a removable deck plate that can be installed for heavy weather, and to protect the speakers from the elements when not in use...
At any rate, I'd be inclined to cover that up, and make sure that cockpit locker lid is gasketed or reasonably well sealed, as well... If there is any inshore body of water where a 27-footer stands a decent chance of getting knocked down or pooped, it would be San Francisco Bay... (grin)
Cockpit speaker shared by Stereo And VHF ? jjablonowski Electronics 8 03-18-2011 07:01 PM
How to make a 1/2 through hole a 1 1/2 through hole? SanDiegoChip Gear & Maintenance 44 04-26-2010 07:09 PM
speaker boxes QuickMick Gear & Maintenance 3 01-06-2010 11:44 AM
Speaker Wiring netscheid Gear & Maintenance 1 04-04-2009 07:01 PM
