Old 09-20-2011
synapse is on a distinguished road
Buying a used sail - something does not make sense to me
Hello,
As you may know, I purchased a 22 foot sailboat (my first) and am taking up this sport. Since my headsail is a genny (130%) my instructor stated it may be best if I also purchase a jib around 80% or so. I cannot argue with his logic, as this makes sense to me during times of stronger wind.
My current headsail measurements are:
Leech: 24 feet, 4 inches
Luff: 20 feet, 8 inches
Foot: 10 feet, 11 inches
Now my (perhaps dumb) question...in looking at used sails online, it seems the Luff is always longer than the Leech. How is this possible mathematically? The leech is the hypotenuse, which should always be longer (as in the case of my sail dimensions above), right???
Thank you
synapse
Old 09-20-2011
BubbleheadMd's Avatar
Chastened
BubbleheadMd will become famous soon enough
Send a message via Yahoo to BubbleheadMd
Because the angles are not perfectly perpendicular. For good, used sails, check with Bacon Sails- Bacon Sails & Marine Supplies.
No affiliation, just a happy customer.
S/V Old Shoes
1973 Pearson 30 #255
Old 09-20-2011
apogee1mars's Avatar
apogee1mars is on a distinguished road
How do you start a thread? I cannot seem to figure it out duh....
Old 09-20-2011
Sublime's Avatar
Quirky
Sublime is on a distinguished road
It's not a flat triangle. The leech needs to be long enough for sail twist.
How much beer, pork rinds, and slim jims have you sent the admins? When you fulfill the bribe, a "new thread" button will appear at the top of the forum.
A ship in harbor is safe, but that's not why ships are built.
My girls:
1974 Alcort Minifish-Minifish
2001 Drascombe Lugger-Penelope
2004 Hunter 260-Miss Muffet
Old 09-20-2011
BigZ is on a distinguished road
Sounds like you might be mixing the luff and leech terms. Luff is the edge of the sail that attaches to the forestay.
Old 09-20-2011
Barquito's Avatar
Barquito
Barquito is on a distinguished road
If the sail forms a right triangle with the tack around 90 degrees, then, the leach should be longer than the luff. If the clew is cut higher, then the leach could be longer than the luff.
Old 09-20-2011
jackdale's Avatar
jackdale will become famous soon enough
The tack cannot be 90 degrees, it will always be less. Unless the tack is high off the foredeck.
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
Old 09-20-2011
Oops..yes, I confused the two dimensions (embarassed). Well..moving on and corrected:
My current headsail dimensions are:
Luff: 24 feet, 4 inches
Leech 20 feet, 8 inches
The 100% Jib would be at 8 foot, 5 inches according to my boat dimensions.
Since I am looking to get another headsail for heavy weather, do these dimensions make sense to purchase (or similar)?
Luff: 20 feet, 0 inches
Leech: 18 feet, 2 inches
Foot: 7 foot, 1 inches
Obviously, it would be a reduction of all headsail dimension..is that too much of a reduction?
Thank you
synapse
Old 09-20-2011
Sublime's Avatar
Quirky
Thank you
synapse
That'll teach me to give you the benefit of the doubt.
If 8' 5" is the foot for a 100% jib, then by my squirrel math, the 7'1" foot would be consistent with about an 80% jib.
My girls:
Old 09-20-2011
Thanks Sublime...just making sure reducing the other dimensions so much makes sense as well....soooo much to learn. I truly appreciate all the feedback. Someday, perhaps I will be on the other end giving advice (well..maybe
Sanity Check-Does this route make sense? creedence623 General Discussion (sailing related) 4 03-01-2010 04:30 PM
does it make sense to buy a boat without an engine and convert it to electric? rmeador Gear & Maintenance 32 02-25-2010 02:46 PM
This doesn't make sense poopdeckpappy Gear & Maintenance 3 05-09-2008 10:27 PM
Does it Make Sense??? sailingdog Off Topic 20 12-09-2007 08:57 PM
