Like Tree17Likes
Old 09-25-2011
flyingwelshman's Avatar
flyingwelshman will become famous soon enough
First anchoring in the dark.
So on Friday night I was sitting on my boat at the marina.
I had arrived later than expected from work.
My original plan was to stay at the marina overnight, then head up to an anchorage in the morning.
The anchorage is about 10 miles from the marina.
The forecast was for light and variable winds beginning early Saturday morning. The weather on Friday night was rain, with a chance of thundershowers and winds 15 – 20 from the Northeast.
After a bit of farting around, I came to the decision that I would rather sail than motor up to Lost Bay. It was about 5:30 and I figured on at least 2 hours to get there. I estimated it wouldn’t be full dark until about 8:00. Rather than sit on the boat, or, go to the on-site restaurant and look at the cute bartender, I thought I could make it to Lost Bay before dark.
By the time I got the boat ready to go, put on my rain gear and trusty Sou’wester and cast off, it was close to 6:15. Once I was underway I realized that I had left my tiller pilot at home. I hadn’t taken the sail cover off, so I set my jib and hand-bombed it up the bay.
The rain started off as a drizzle but got progressively stronger until it was a full-bore downpour. There was no one else on the water. The wind was blowing at about 12 knots and I was making good headway under jib alone. It was very pleasant. About half way up to Lost Bay the mist started to thicken to more of a fog. The heavy cloud cover, rain and thickening fog made it pretty dark out. I switched on my running lights and got my horn close to hand.
I came to realize that I wasn’t going to make Lost Bay before dark. I considered turning back: heading for the well-lit safety of the marina. I guessed that there would probably not be anyone else at the anchorage, and I was very familiar with the Bay, so why not carry on?
It wasn’t long before it was very dark and the visibility was pretty limited. I could barely make out the range to the west of where I needed to go in. I know that there is some pretty snotty stuff to the East (Osprey Bank) so my plan was to sail to the point where the north/south and east/west ranges intersect then drop my sail and motor over to the channel that is marked by a starboard hand day beacon. This went as planned and I fired up old smokey and motored towards shore.
It’s hard enough to see the day beacon in broad daylight: given the conditions on Friday night: torrential downpour, fog etc. it was next to impossible. I headed in the direction I thought was close and beamed the rocky shoreline with my flashlight. I saw a pale shape on the rocks and trusted my memory. For once it hadn’t let me down and I entered the channel.
The channel going in to Lost Bay is very narrow (I’m guessing 25 – 30 feet). There are submerged rocks and other nasties on either side. On Friday night I could barely make out either side! Chartplotter don’t fail me now!
I motored through the channel and turned down into Lost Bay. I played my flashlight across the channel as there are a couple of Javex-bottle-marked alligators you want to avoid.
The bay is pretty much consistently 8’ deep, except close to each shore where the Canadian Shield eases down into the water. I know from experience that getting too close to the sides will give you that sinking feeling of keel-kissing-limestone. On Friday night I couldn’t see the shore. I trusted to my chartplotter and scanned the anchorage with my light. I could barely make out a dim anchor light and ghostly hull of another boat at anchor.
When I was in what I thought to be a suitable spot, I lowered my anchor and paid out my rode. I wasn’t entirely sure exactly where I was hooked, but, after backing down, I knew that, at least, my anchor was set.
Now usually I am pretty lackadaisical about checking my anchor. My wife is constantly up in the night and always checks to make sure we are in position. On Friday night I leapt up at every creak and tried to make out my position in relation to the rocks and the other boat. I was pretty certain that I would hear and feel the crunch of my keel against the hard rock.
As it turned out I didn’t hit anything. When dawn finally arrived I found that I was anchored in a pretty good spot: not close enough to the shore or the other boat to hit, and not right in the channel.
This was my first night-time anchoring. It was a little intimidating, but, when all was said and done, a great experience.
Then, to ice the cake, I looked out of the companionway in the morning and saw a bird that looked very distinctive flying over the cottage at the entrance to the bay.
I am pretty familiar with our local birds and am quite confident in my identification, but I pulled out my trusty binocs for a closer look. Sure enough the bird was a mature Bald Eagle! Now, for those of you on the East or West Coast, this is no biggy. I’ve even seen plenty of these beautiful raptors in Manitoba, but to see one in Southern Ontario, is pretty special! I know that they are breeding here, but I have only seen one other (in Guelph in 1988) in Ontario. Very cool!
Another benefit to the dark is that it’s hard to gauge size. In the morning a lady from the other boat kayaked past me and told me that they though I was a 50 footer coming in in the night. Not bad for 26 feet…
1989 Hunter 30'
Southern Georgian Bay
'Nautai te salutamus!'
Old 09-25-2011
tdw's Avatar
tdw tdw is offline
Super Fuzzy Moderator
First time in the dark and in fog to boot. Well done.
bwalker42 likes this.
Old 09-25-2011
jackdale's Avatar
jackdale will become famous soon enough
In these situations I love radar. I anchored in the dark in fog in Port McNeil last month. Just pick a wide open spot in the middle of the blips.
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
Old 09-25-2011
BryceGTX is on a distinguished road
When I saw you are from "Southern Georgian Bay", I had to locate this area on my charts to see where it was.
Just so others know, this side of Georgian Bay is littered with thousands of small islands of rock. It is one of the most unique places I have been to. It represents one of the most challenging cruises I have ever taken.
Many years ago, prior to Lorain and GPS, we took a trip along what was called the small craft route. Through these islands. This small craft route passes just north of the area flyingwelshman was piloting.
The route is so tricky, I used 38 charts and plotted 142 rhumb lines over the 100 and some mile trip. I still have the charts and the plotted course. We ran only during day.
Many "channels" (loosely speaking) are quite narrow as flyingwelshman said, framed with rock outcrops. Most navigational aids we saw were small signs nailed to poles.
Although a plotting GPS is quite handy, this is not an area you want to be too far off course.
Good job flyingwelshman
BTW.. we started from Penetanguishene... is that by chance where your home base is?
Flybyknight and messer999 like this.
Old 09-26-2011
WanderingStar is on a distinguished road
Sounds great! The very essence of cruising. I did similar once, feeling my way by depthsounder and spotlight into an unfamiliar spot in the dark. I was pleased and a bit scared in the morning to find myself neatly anchored in the middle of a rockbound cove
Old 09-26-2011
SVAuspicious's Avatar
Mermaid Hunter
SVAuspicious is on a distinguished road
Thanks for sharing.
I was surprised that you didn't invite the cute bartender along until the fact of a wife was revealed toward the end.
sail fast and eat well, dave
S/V Auspicious
AuspiciousWorks.com
beware "cut and paste" sailors.
Old 09-26-2011
AdamLein's Avatar
AdamLein will become famous soon enough
Nicely told... Very atmospheric. And good on you for going for it when there was a lazier and arguably more comfortable option.
I don't have a very powerful flashlight, so it's worse than useless to try to use it to see the shore. I've often found that my binoculars are very good at letting in enough extra light to help me make out details that would have been invisible in the dark.
s/v Essorant
1972 Catalina 27
Old 09-26-2011
cb32863's Avatar
Boat Owner
cb32863 is on a distinguished road
Nicely done!
Umquam Porro
S/V Papillon 1977 O' Day 25
Old 09-26-2011
jrd22's Avatar
Courtney the Dancer
Well done. Not to take anything away from your successful navigation in the dark, rainy, foggy, rock strewn area but... I'm not sure I would have made the decision to go knowing what a difficult and dangerous route I would have to take in the dark if it took me even a wee bit longer than expected. When you got part way and the conditions deteriorated you had the choice to turn around instead of knowingly putting yourself and your boat in an unnecessary and risky situation. The fact that it turned out OK doesn't negate the fact that you made the conscious decision to put yourself in the situation. I'm not saying that you did the wrong thing, I've done the same thing in the past, just bringing up the fact that generally it's not a good idea to choose to enter a tricky entrance at night in poor visibility if there are alternatives.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 09-26-2011
AdamLein's Avatar
I dunno. I think the fact that he was familiar with it makes somewhat of a difference. He also knew what sort of weather conditions he could expect. In the end it seems like it was not an unreasonable risk, and once in a while it's nice to take not-unreasonable risks
flyingwelshman likes this.
s/v Essorant
1972 Catalina 27
Dark and stormy SimonV Provisioning 42 06-11-2010 12:42 PM
light vs dark xort Gear & Maintenance 5 09-19-2008 09:12 PM
The Dark Side drynoc General Discussion (sailing related) 25 08-08-2008 12:55 PM
It is dark here max-on General Discussion (sailing related) 4 07-23-2008 04:56 PM
Dark water drynoc Gear & Maintenance 3 03-04-2007 10:10 PM
