Old 09-26-2011
BubbleheadMd's Avatar
Chastened
BubbleheadMd will become famous soon enough
Send a message via Yahoo to BubbleheadMd
SIMRAD TP1600 tiller pilot rating?
Does anyone know what size and displacement boat that a Simrad TP1600 is rated for?
I can easily find the user/owner manual online, but it's written for the 1600 & 2500, and it only states that the 2500 is good up to 14 meter boats. It doesn't mention the limitations of the 1600 at all.
I don't want to just assume that the 1600 is rated to handle the same loads as the new TP10.
S/V Old Shoes
1973 Pearson 30 #255
Old 09-27-2011
Chastened
Bump.
Seriously, no one knows?
S/V Old Shoes
Old 09-27-2011
kwaltersmi's Avatar
Broad Reachin'
kwaltersmi is on a distinguished road
The stated difference between the 1600 and 2500 "is in the linear drive mechanism, the latter being an extremely high efficiency recirculating ballscrew, offereing greater thrust and faster actuator travel from lock to lock." That doesn't clear things up, so I can see where you'd be confused.
My personal experience is with an Autohelm ST1000 on my ~8000lbs 28 footer. I would think the TP1600 should handle your P30 in calm to moderate conditions. I've found that if there's heavy air (above say 18kts) or lumpy/rolly seas, my Autohelm works too hard for my comfort. I suspect if your P30 is trimmed correctly and it's a nice day, go for it! If it's snotty, I'd keep the tiller in the skipper's hand.
Old 09-27-2011
Chastened
That's helpful. That's pretty much how I'd use it.
S/V Old Shoes
Old 03-01-2012
ppiccolo1's Avatar
ppiccolo1 is on a distinguished road
Bubblehead, Have you had a chance to use the 1600 yet? The Cat25 I just purchase has one. I was looking at a tp10, but if the 1600 works well, it saves me $400 and the install.
HELP, need install parts for Simrad Tiller Pilot jim7289 Introduce Yourself 13 08-17-2010 08:13 PM
Advice for repair of tiller pilot->tiller connection jgsteven Gear & Maintenance 2 09-11-2009 04:53 PM
Simrad Tiller Pilot jerryr Gear & Maintenance 21 09-25-2008 09:47 PM
Simrad wheel pilot installation captain_jim Gear & Maintenance 1 02-13-2003 05:11 PM
Simrad vs. Navico Tiller Pilots jamesmm Gear & Maintenance 4 11-03-2001 03:03 PM
