10-02-2011
How much can I load on my boat.... Necessary knowledge
I worked out the pounds or tons per inch of immersion for the S/V Rapture.
It is 2.09 tons or 4670.8 pounds per inch of immersion.
Now how was it done.
Displacement / Cube Root of (LWL X Bwl X .76) = TMI or PMI
LWL = Length of Water line
Bwl = Beam of vessel at the water line
.76 = Is a constance for this formula
So the LWL of the Rapture is 32.25 ft, the Beam at the water line is 13.12 ft
and the displacement is 32000 pounds. And using the above formula I came up with the above answer.
My weight is 200#. Weight of possible guests may total 460# overall for people on board is 660#.
Food for a week. 40# per person per day for 7 days is about 1120
personal gear of the people totals about 120#
So I will have about 1900# estimated total and immersion the Rapture about another one half inch or there about.
On the food I might have over estimated, but some of us do enjoy eating and you do need the calories when sailing. Diets are left onshore when boarding a board.
Personal gear? When working off shore... I had to pack about everything needed and that came out to about 60 to 80 pounds... But I was gone for three months and it was winter. So for summer cruise for a week... the guests may bring 30# of gear but may only use about 10# if warm summer nights abound for the cruise.
The fuel & water is figured into the displacement... But if you bring bottled water that goes into grocery stores.
For small boats; read the builders plate carefully. Because everything you add to that boat is part of the Max weight that can be carried. This includes the outboard, fuel, and so forth.
1600 Ton Master, 2nd Mate Unlimited Tonnage
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Maritime Instructor To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
S/V Rapture
