10-07-2011
By worrying about this concept of "syncing," you're making it much more complicated than it is. What is a route or a track? It's nothing more than a list of coordinates, maybe with some time stamp and speed information.
If you want to plot routes on a PC, you can use any program to do it. It's a good idea to make sure your charts use the same datum and projection as the GPS. I really like SeaClear for this, because it uses NOAA's free downloadable charts and it's really easy to move from one chart to another by double clicking on the margin. I also get extra confidence by using NOAA's genuine charts to plot routes, since it's a double check against possible errors in Garmin's charts.
Once you've saved the route on your PC you just need to convert it to .gpx format and transfer it into the GPS or chartplotter. For this, I use g7towin and MapSource. The former is freeware; the latter can be downloaded for free from Garmin's website as an update. There are well documented tricks to get the update to install a fresh copy. Just Google it.
If you want to export tracks from the GPS or chartplotter, just reverse the direction with the same software.
Although I prefer SeaClear for plotting routes at home, I also use OpenCPN for real-time chartplotting in my cockpit. All the tricks for transferring routes and track also work for OpenCPN.
I would not go and return a chartplotter because Garmin's website doesn't say it will work. I suspect you can get it to work if you try. It may just be that Garmin has lousy documentation. I'd suggest trying it first, and then "vote with your wallet" if you're not happy with the result.
1998 Catalina 250WK "Take Five" (at Anchorage Marina, Essington, on the Delaware River)
1991 15' Trophy (Lake Wallenpaupack)
