Refrigeration-Frigoboat Keel Cooled vs. others? - Page 6 - SailNet Community
 4Likes
post #51 of 70 Old 10-20-2011
Unpaid Intern
josrulz's Avatar
So, T37Chef, did you come to a decision?
1984 Sabre 34 Mk I
josrulz is offline
post #52 of 70 Old 10-21-2011 Thread Starter
T37Chef's Avatar
Arggg...not yet. You?
Shawn
T37Chef is offline
post #53 of 70 Old 10-21-2011
Unpaid Intern
josrulz's Avatar
Actually, we're going with the keel cooler. Just placed the order today. There are pros and cons to every solution. We think this one is the best fit for us. Who knows if we're right? Practical Sailor didn't take me up on the personalized, localized, customized test, so I just had to pick something.
-J
1984 Sabre 34 Mk I
josrulz is offline
post #54 of 70 Old 03-31-2012 Thread Starter
T37Chef's Avatar
Re: Refrigeration-Frigoboat Keel Cooled vs. others?
Still haven't made a purchase...but the defender sale is this weekend
Shawn
T37Chef is offline
post #55 of 70 Old 04-01-2012
Over Hill Sailing Club
smurphny's Avatar
Double arrrrgh! I'm in the same boat here. Would like to get the Defender sale price but still torn over which unit to use. I like the amp rating of the Isotherm SP Evaporator but don't like the fact that it stops working if the boat is out of the water for a few days. Same w/ keel cooler models. Am thinking of just going with the smallest fan unit for about 1/2 the cost, about the same amp/hr rating.
smurphny is offline
post #56 of 70 Old 04-06-2012
Mermaid Hunter
SVAuspicious's Avatar
I have an Isotherm SP refrigerator and separate freezer. They work fine on the hard. Power consumption goes up but you are usually plugged in so that isn't a big deal. You have to be sure not to leave the plug in the sink drain as it acts like a chimney for the heat exchanger.
SVAuspicious is offline
post #57 of 70 Old 04-06-2012
smurphny's Avatar
Thank you for that info. This is the way I'll go, with the smallest unit. I just assumed the heat dissipation went to zero when out of the water. The only thing I need to check out is the feasibility of cutting off the sink drain which is fiberglass tube molded right into the hull. It's not a thru-hull fitting.
smurphny is offline
post #58 of 70 Old 04-06-2012
Mermaid Hunter
Definitely feasible. Although it may sound like major surgery I would cut out the entire tube and put in a thru-hull and run hose from the sink drain to the thru-hull. It will be easier to run from the hole in the sink to the hole in the hull than to try to work with the fiberglass drain.
post #59 of 70 Old 04-07-2012
smurphny's Avatar
Found a new sp2055 on ebay for a really good price, right from Indel. Went over to boat to assess the location and there is just enough space to drill out the old fiberglass standpipe and replace with the new heat exchanger unit. I don't like drilling a 2 1/2" hole but the .55 amp rating on this unit is too good to not do this. It'll leave me amp/hrs to spare. Also, just above where it will come through is a small hatch area in the counter that will work great as a completely new fridge location which I can super-insulate with some polyisocyanurate. The original box on the starboard side is WAY too large anyway, probably 6 cu ft. Project underway....finally! Thanks for your input.
smurphny is offline
post #60 of 70 Old 06-12-2012
I wonder if JonEisberg's lack of oil collection is related to the cooler being near the waterline? It would make sense that if the compressor is lower, that might solve the problem. I've met people who had the same blockage problem, btw.
- Alan
AlanF is offline
Keel cooled refrigeration brokesailor Gear & Maintenance 9 10-15-2011 12:47 PM
Frigoboat Installation stevemac00 Pacific Seacraft 9 10-12-2010 10:07 PM
Frigoboat Refrigeration obelisk Gear & Maintenance 20 04-30-2010 05:48 PM
Raw water cooled issues? davidpm Diesel 5 11-10-2009 09:15 PM
Adler Barbour Water Cooled Refrigeration bobbosax Gear & Maintenance 1 12-26-2008 10:27 AM
