Like Tree1Likes
  • 1 Post By bljones
Old 10-11-2011
jblack is on a distinguished road
Fairing
Good day everyone,
what boards are you using for fairing? Which is more effective board 3M or handmade?
Old 10-11-2011
tommays's Avatar
I have the 3M flex board did not use it that much as it was a bitch to hand power and i was able to borrow a powered long board
Picking the paper is the bigger issue as the basic gold paper was really bad in life and clogging
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 10-11-2011
Boatsmith's Avatar
BoatSmith
Boatsmith is on a distinguished road
We use both the 3m boards and pieces of wood. We also like the 3m imperial purple paper. The 3m has comfy handles. It really does the same thing as a piece of wood cut to the right size. We also use wood when we want a longer board or want one with just a little flex. PSA paper is essential in my book.
BoatSmith ---Boatbuilder
Old 10-11-2011
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
I have the 3m board and it works, however, now mine is bent up a bit after it was squished in my car trunk. Still works, just looks funny.
Merit 25 # 764 "Audrey"
Old 10-11-2011
Part of the solution
bljones has a spectacular aura about bljones has a spectacular aura about
I make my own boards and cover them with PSA sandpaper that I buy by the roll. I have 12", 18", 2', 3' one man boards, and a 5' two man board... which is an exercise in cooperation and communication especially if it's your wife's hand on the handle on the other end of the board.
1/4" mahogany ply coated with a coat or two of epoxy makes for good durable springy boards.
fullkeel7 likes this.
It's 5 o'clock somewhere:
Old 10-11-2011
paulk's Avatar
paulk is on a distinguished road
Second BJ's use of thin ply. It doesn't have to be mahogany to curve uniformly and be stiff enough to be effective.
Old 10-13-2011
I also use sandpaper with spray adhesive and usual piece of wood, but fairing desks aren't enough flexible.
Maybe somebody could comment on other brands?
Old 10-15-2011
Do any of you have any experience with the Flexicat boards? http://www.flexicat-tools.com
keel fairing lofty22810 Gear & Maintenance 3 12-07-2008 04:21 PM
Keel Fairing BarryL Gear & Maintenance 34 03-21-2008 10:15 AM
Keel fairing sailorbri Racing 11 03-14-2007 04:04 AM
Fairing compound? Jotun Gear & Maintenance 2 02-22-2007 04:22 PM
Fairing katytoo Gear & Maintenance 1 03-26-2006 06:06 PM
