10-12-2011
Originally Posted by denverd0n
Read what the brochure says...
"The deck and internal cabin headliner sandwich end grain balsa..."
Sounds to me like a description of fiberglass on top, plywood on the bottom (the headliner), and balsa in between. The picture is just vague enough so that you really can't be certain if the balsa is completely encased in fiberglass or not.
On the other hand, this is a 30+ year old boat that has held up well and has no soft spots. If it were inherently weak, significant problems would have become apparent by now. Though it is a little unconventional, it appears that Nor'west put it together well. Frankly, I wouldn't worry about it.
The balsa would have to encapsulated for the cored structure to have the necessary strength... if the lower skin was indeed plywood, I suspect the OP would have had considerable difficulty separating it from the core. Since this boat seems to be in good condition and well built I think the confusion may lie in the builder using the term 'headliner' for the inner skin...
... but anything is possible, of course...
1984 Fast/Nicholson 345
