Philadelphia Area Sailing for a Novice on a 25' SK - Page 4 - SailNet Community
post #31 of 61 Old 10-18-2011 Thread Starter
Asleep at the wheel
jimgo's Avatar
RhythmDoctor, thanks for the link; I've been following that story with interest! Based on what I've read, I don't think I'd be trying Barnegat inlet anyway - I'd either go the ICW or down to the next inlet South, whose name escapes me now.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #32 of 61 Old 10-18-2011
TakeFive's Avatar
I forgot about ICW through that part of New Jersey. I don't know those waters at all, but someone here once warned to always check the operational status of all the bascule bridges before departing, since they are sometimes down for maintenance/repairs. That might also be covered in USCG's weekly LNM reports. I'm sure Dave or Jim McGee knows more about this.
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
post #33 of 61 Old 10-18-2011
TakeFive's Avatar
[hijack]
Ulladh - Last spring you said your plan was to stay in the water at Anchorage all winter. Are you coming over here? (I'm hauling early Nov.)
[/hijack]
TakeFive is offline
post #34 of 61 Old 10-18-2011 Thread Starter
Asleep at the wheel
jimgo's Avatar
LOL...inoperable bridges - that's something I hadn't considered, and could pose a bit of a problem!!! Maybe I'll be building that A-frame a little sooner than I expected!
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #35 of 61 Old 10-19-2011
chef2sail's Avatar
The next Inlet down ( Little Egg Inlet) is worse choice to go out than Barnegat. It has frequently shifting shoals. You can continue down the intercoastal and go out Absecon Inlet which is an easy one (Atlantic City. The intercoastal to Atkantic City from Barnegat is norrow with mskinny water, but doable. Make sure you have Boat US unlimited towing. You best bet is to go ourt Barneget in the AM when it is calm, 85% of the time. Also Greater Egg Inlet to get behind Ocean City is no picnic either, with freuently shifting shoals and rollers across the inlet in the afternoon.
Barnegat Inlet to Ocean City is approx 50 miles or a 12 hour trip. Atlantic City to Ocean City is 22 miles. You can break this up by anchoring across from Clam Creek in Atlantic City or staying at Kammermans in Clam Creek (2.50 a foot vs 5 dollars in the Farley Marina.
No intercoastal from AC to OC as there is a fixed bridge in Longport.
Make sure you engine is checked out before you do this also. If I rememeber the Cat 25 is a pop top model with an outboard. Expect to average 4 knots, less against the tidal current even.
For more info feel; free to PM me.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #36 of 61 Old 10-19-2011
I don't know the air draft on the C 25, but Ocean city Roosevelt Blvd fixed bridge is 35ft vertical clearance. There are some other fixed bridges I think at Sea Isle and Avalon.
My Havsfidra has an air draft of 28ft.
Rhythm
I will haul out this winter, I have a split in the rudder, above water line but it will travel. The winter project will be to use the old rudder as a template for new.
1970 Havsfidra 20 by Fisksatra
On the Delaware River at Fox Grove Marina Essington PA
Ulladh is offline
post #37 of 61 Old 10-19-2011 Thread Starter
Asleep at the wheel
jimgo's Avatar
Ulladh, the mast height above water (air draft) is about 33' for a C25; the mast is 28'. I'm not sure how high up the antenna sticks above the mast; I'll have to measure that when I take it down.
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #38 of 61 Old 10-19-2011
Waterway Cruising Guide | Waterway Planner
Go to waterway planner and zoom in to the NJ section, chart is overlaid on google map and contains update notes including shoaling and bridge work.
33ft under a 35ft bridge may be a problem with powerboat wake at high tide.
Ulladh is offline
post #39 of 61 Old 10-19-2011 Thread Starter
Asleep at the wheel
jimgo's Avatar
Thanks, I hadn't come across that web site!
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #40 of 61 Old 10-21-2011
Bermudahigh's Avatar
the City of Ocean City has purchased a marina around 2nd and bayfront. While its open and exposed to a long fetch, it will be on the cheaper end of the slip options. Will try to find pricing info for you.
Bermudahigh is offline
Novice at sailing and first time buyer. xhevi Boat Review and Purchase Forum 22 12-29-2011 03:56 PM
novice question seas/ swells/winds and kids.. pleasure sailing ONLY... Motherof3 General Discussion (sailing related) 58 08-16-2010 09:21 PM
Philadelphia Area Sailing? CapnSantiago General Discussion (sailing related) 26 06-14-2010 06:56 AM
Pirate Capital and its crew see stormy sailing (The Philadelphia Inquirer) NewsReader News Feeds 0 02-05-2007 04:16 AM
Smooth sailing after rough start (The Philadelphia Inquirer) NewsReader News Feeds 0 12-08-2006 04:16 AM
