10-15-2011
Originally Posted by PCP
Not disputing that but really interested in more information. Can you post a link to that information if possible? The Kanzaki gearbox is the one that they are using on new models? That applies also to folding propellers?
It seems logical to me that a free spinning propeller creates less drag but it also creates unnecessary wear on the material and I have heard that it was prejudicial, something related with lack of lubrication. Can you comment on this?
Yanmar MSA .pdf
"Advisory Number: MSA08-003:
DATE February 8, 2008 Dealers and OEMs
TO: All Marine Distributors
SUBJECT: Gear in Neutral While Sailing All MODELS:
All Sailboat Engines
We continue to get questions regarding the correct gear position while sailing with the engine OFF. This advisory is issued as a reminder; Yanmar requires that if sailing with the engine OFF (not running) the transmission shifter must be in the neutral position or internal damage to the gear or sail-drive will result. This damage will not be covered by Yanmar’s Limited Warranty. Please instruct customers and dealers who deliver the sailboat to the customer, of the correct (Neutral) position for the marine gear while sailing.
If the customer desires that the propeller shaft not spin while sailing, either a folding propeller, shaft brake, or other suitable device may be used. However, Yanmar accepts no responsibility for the selection, installation, or operation of such devices. Please also refer to Marine service advisory “MSA07-001_Yanmar Sail Drive Propeller Selection” for additional information.
If you have any questions regarding this advisory please contact a Customer Support representative."
The guy from Yanmar admitted that prior to 2008 they did not take much of a position either way in regards to reverse or neutral, hence the constant confusion on the forums when talking about Yanmar's.
This info does NOT apply to other engine makers!
______
-Maine Sail / CS-36T
