Like Tree5Likes
  #21
Old 10-17-2011
Jeff_H's Avatar
Administrator
Jeff_H has a spectacular aura about Jeff_H has a spectacular aura about Jeff_H has a spectacular aura about
This is really heart wrenching. The Ode to Joy site just exudes a sense that here is an owner who loves his boat. In this electronic age it seems stunning how quickly a search can turn up a float plan of sorts.....
"I can report the Alden Challenger is a great pleasure to sail, tracks well, accelerates quickly even in light air, hands off steering once sails are trimmed, turns a tight radius, settles quickly into easy motion when hove to, and glides forever when turned into the wind. Now, I am ready for longer sails, overnighter, perhaps dare I say it, a late fall cruise to Annapolis and back...I am going to enjoy this part."
  #22
Old 10-17-2011
gucio123456 is on a distinguished road
so sad to see
  #23
Old 10-17-2011
Tempest is on a distinguished road
Yes, I found that blog and wondered if it was the same vessel. I went through the blog posts and photos. This vessel was painstakingly restored. I think I remember reading that the masts were laying underwater at the yard during Irene, and survived.
It is heart wrenching. The only consolation is that everyone was taken off safely.
Tempest
Sabre 34
Morgan, NJ
  #24
Old 10-17-2011
smurphny's Avatar
Over Hill Sailing Club
smurphny is on a distinguished road
Originally Posted by RhythmDoctor View Post
The outdated part is worth emphasizing. These satellite pics can give a general idea of the area, but boaters are also well advised to heed the warning on Note C of NOAA's chart for this area:
Of course. Some of the Google images are YEARS out of date and the resolution is not fine enough see buoys anyway but they do give an overall picture of what you may be getting into. Some people are using these in remote areas where printed charts may be 100 years out of date.
When heading south (drawing close to 6'), I make sure to choose a weather window to avoid these NJ inlets and make it to Delaware Bay, although Cape May Inlet is straight forward enough if weather is good. Would never attempt with poor visibility/at night. At night, even inlets you are familiar with can be confusing.
  #25
Old 10-17-2011
JonEisberg will become famous soon enough
Originally Posted by Plumbean View Post
When I look at the NOAA chart for Barnegat Inlet, it shows the lighted buoy out at the end of the submerged part of the north jetty, so you would have to cut inside it in order to ground on the submerged jetty when arriving from the north. Am I missing something?
So much for Local Knowledge, I suppose... (grin) My apologies, I did a rather poor job of describing what I meant, there. I'll plead the excuse of the lateness of the hour of my posting, and the fact that I had raised a glass or 2 too many last night, to the memory of Indy Champion Dan Wheldon...
The outermost portion of the north jetty has been reduced to somewhat of a pile of rubble by the wave action over recent years. For years the light on the jetty had been a more substantial tower, which eventually was at risk of toppling over, and was eventually replaced with a light on a single pole driven into the bottom, rather than mounted on top of the rocks... But, if you look closely at the pic below, you can see it is placed slightly to the outside of the rocks...
Add the fact that the channel normally favors the N side to a considerable degree - there is usually a lighted green buoy just inside the jetties, often placed about 2/3 of the way across the inlet towards the N side... From there on in, the channel run quite close to the rocks, generally closer than the red course line below would indicate...
My impression has always been that as the end of the jetty has been broken down, there is a significant amount of underwater obstruction from the debris extending a bit more to seaward... It can certainly appear that way from the visible wave action there in certain conditions, and friends who fish around the rocks there believe there are rocks that extend slightly further out... I'll take their word for it, I've no inclination to investigate that any more closely...
  #26
Old 10-17-2011
chef2sail's Avatar
chef2sail will become famous soon enough
Very sad to see.
I have transited Barnegat Inlet over 150 times in many differening conditions. I also lived at the South Jersey Shore for 18 years before moving to the Chesapeake 12 years ago.
I always warn boaters that this inlet above all other jettied inlets in NJ is far away the most trecherous and dangerous. The large body of water behind it draining seaward ( Barnegat Bay) on the ebb tide can create a 3-5 knot current easily as it gets squeezed between the rock jetties. Cape May, Atlantic City are safe. Barnegat is not. Add to it the shoal on the inside of the south jetty starting ahlfway down it forces you to hug the north jetty rocks. As if this not enough the depth approaching the inlet from the sea are shallow on either side of the markers starting about 1/4 mile out. I recommend to al coming in this inlet do not short cut it like Atlantic City and acpe May and Manesquan. Start out almost at the Bell Bouy and come right down the straightaway. The shoals on either side will often cause the swells to break and roll across this inlet especially on the outgoing ebb tide and South east or northeast winds.
This is one inlet I avoid at night as I want to see my way in here. Caharts are no good nor are pictures as the sands shift and the breakers vary according to wind direction or tides. This must be seen with the naked eye to ascertain the safety of approaching or avoidance.
The channel in is quite tricky as I have said. After you transit very close to the north jetty, you dog leg hard left accross the back of the inlet with the tide running cureent running abeam with 3 ft on your inland side of water. This inlet is not for the faint of heart and in no way will I Monday morning quarterback here. Suffice to say even with over 150 trips I woulkd not attempt in the dark under any circumstances.
Good bless the sailors that they were saved. Kudos to the CG for the rescue. Every year there are numerous rescures in this inlet. Stay away at night and in Northeastern. Stay a way and live to see another day.
Dave
ottos and WanderingStar like this.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
  #27
Old 10-17-2011
GaryHLucas is on a distinguished road
About 28 years ago I took my Hunter 27 out the Barnegat inlet for the day. This is before they 'fixed' it! On the way out we had the sails up the engine running, all hatches sealed, life jackets and lanyards on. A small runabout with 3 adults and two small children, no life jackets on passed us going out. We had a fine day out on the ocean. Coming back in we were again prepared for the worst. Suddenly we heard this roar, and heading towards us was this huge breaking wave! My friend asked me what was going to happen. I said I didn't know, but I was pretty sure we were going to get wet! The wave came up under us and boiled all around the stern as we surfed into the inlet for probably a hundred yards, but no water came into the boat. Then it was gone and we motored on in. I have always wondered about the sai... idiots in the small boat!
Gary H. Lucas
  #28
Old 10-17-2011
neverknow's Avatar
neverknow is on a distinguished road
Barnegat inlet - Google Maps
You can zoom in and see the light plus the channel on the north side.
  #29
Old 10-18-2011
The owner has posted a remarkably sober and candid account of what happened here:
How it Happened
Damn, I wish they had been able to drive it up on the beach, I could definitely get onboard with a Michael Calabrese-style rescue effort for this gentleman...
He'll sail again some day, you can tell...
  #30
Old 10-18-2011
LandLocked66c's Avatar
Sunsets and Warm Beer....
LandLocked66c is on a distinguished road
Man, that would suck! Mistaken buoys for the inlet.
Sounds eerily similar to what may have happened to Rule 62. Seasickness and unfamiliarity with the waters...
1971 23' Oday Pop Top
S/V Frida
You can't steer a boat that isn't moving? Just like a life - P. Lutus
You may post attachments
You may edit your posts
Adding a 50A AC inlet to a boat with two 30A labestia Electronics 8 02-19-2010 08:30 AM
Sailing to Barnegat Inlet fdefran12 General Discussion (sailing related) 6 06-29-2009 01:46 PM
Missing Sailor Found Off BARNEGAT Inlet Freesail99 General Discussion (sailing related) 14 10-09-2008 11:22 PM
Bottom Boat Strip/Paint in Upper Barnegat Bay, New Jersey Trescool Gear & Maintenance 1 03-24-2008 12:50 AM
Moriches Inlet vs Fire Island Inlet threeofakind Cruising & Liveaboard Forum 1 08-15-2007 08:26 PM
SEO by vBSEO 3.6.1
