Like Tree2Likes
Old 10-16-2011
Moody 46
orthomartin is on a distinguished road
Dumb MMSI question
We sail outside USA and have fed radio lic and FRN. We sold our mono and bought a cat. The cat has an MMSI programmed from previous owner but I assume we have to get a new number with our personal info and lic. info attached to it
The FCC web site seems a bit confusing, what is the procedure here?
Thanks all
Old 10-16-2011
erps's Avatar
the pointy end is the bow
I went through Boats US when I registered our MMSI number. It allows for edits and updates. It's free. I would try registering there and see if it kicks it back because it's already registered.
MMSI Registration for VHF/DSC
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Old 10-16-2011
Zanshin's Avatar
Zanshin is on a distinguished road
You will need a new MMSI. What sort of a radio is the MMSI programmed into? Many require that you bring the radio into an approved shop or to the manufacturer in order to re-program a new MMSI (my ICOM 801 needed to go back to an authorized store). Some devices have the 'cheat codes' available on the web so that you can do the re-programming yourself.
SVAuspicious likes this.
Old 10-16-2011
paul323 is on a distinguished road
I was in the a similar situation (based in California), just went to MMSI Registration for VHF/DSC an changed the owner details to myself. Well, actually it was a bit more complicated as there was some confusion over the old login, but the contact their sorted it out over the 'phone, was very kind and efficient...basically no need to reprogram, just make sure it is registered to you.
Old 10-16-2011
Minnewaska will become famous soon enough
I do not believe the free BoatUS MMSI is valid outside the US where the OP indicates they sail. If it is a US documented/registered vessel, you will have to pay for a FCC MMSI.
I thought that the MMSI stayed with the vessel, so if it already has one, I have to refresh on how it is transferred.
If you must change from a free one to international, the radio typically needs to be reset by a repair shop.
Jeanneau 54DS
Old 10-16-2011
PorFin's Avatar
Señor Member
PorFin is on a distinguished road
The problem with the BoatUS and other on-line MMSI services is that the MMSI numbers they generate are not for international waters.
You're going to need a new ship's station license -- when you apply for this, you can ask for a new MMSI.
As others have mentioned, you may need factory assistance to reprogram the MMSI into the radio. Some models only let you change it a time or two before you hit a firewall.
Old 10-16-2011
Moody 46
mmsi
Yes, Boat US is only for domestic
I am looking for the easiest way to change info with the FCC. I have spent some time on their website but it is typical gov stuff and messy (man they have a lot of forms, in fact there are forms for the forms)
Perhaps I will call monday
Old 10-16-2011
xymotic is on a distinguished road
I'm not an authority, but I think most of the previous answers are incorrect. (minewaska is correct)
It's my understanding that the MMSI, and the Station Lic. Goes with the boat, with the station lic is non-transferrable but the MMSI is.
You'll need to apply for a new ship license, but use the PO's existing MMSI. **IF** he got a MMSI from the FCC. If he got it from boat US, you can't transfer it, and that's spelled out very clearly on fcc form 605 for the station lic.
You can easily also re-register a previous MMSI with Boat US; BoatUS.com: Incorporate Non Renewal FCC Numbers but as stated it won't update the international database, and it won't work on a new station license which you'll need anyway, so it would be best to do it with FCC.
Old 10-16-2011
You just need a new Station license, and when you apply for that it asks for the old MMSI number.
Old 10-16-2011
Moody 46
In conclusion
Couple points here
1) Again, Boat US does not apply here in any way.
2) To work online you must have a FCC Ref Number or FRN
3) You must have at least a Restricted Radiotelephone Operators Permit
This stays with you for life. Remember we are talking outside the US
4) You must have a Station License, this is not transferable between boats.
Finally, last post answered my question. With new Station license you can get online and apply the MMSI with the boat with the updated station info.
No Question too Dumb? Tree Electrical Systems 7 01-29-2011 09:10 AM
Really dumb question.... Mizu General Discussion (sailing related) 52 01-24-2011 05:26 AM
Help--Really dumb question Barquito Gear & Maintenance 4 08-08-2010 02:47 PM
This might seems like a dumb question but I'm new so... MARRSY Gear & Maintenance 8 09-24-2007 10:03 AM
Dumb question, but please help.... FrankLanger Gear & Maintenance 7 07-06-2007 12:12 AM
