Hull Speed? - Page 2 - SailNet Community
 4Likes
post #11 of 23 Old 10-16-2011
4KSB driver.
Guys, I use my GPS as well, and yes it is SOG (speed over ground)... but I have an observation...
GPS is great for pinpoint location, of hand down to with 30 feet in any direction (including elevation). GPS CAN be more accurate, using various other services, and some of the newer/more expensive GPSses use them.
Here is what I am getting at. I don't think GPS is nearly accurate enough (with a basic handheld) to give you accurate enough numbers for speed. Yes I use it too. I think speed is less reliant upon location accuracy but, at these slow of speeds, I dunno how accurate it is.
Has anyone checked SOG of say a standard cheapo GPS handheld with a knotmeter to see how close they are?
As others have said, boat waterline (esp while heeling) changes thus changing max theoretical hull speed.
PS: My max hull speed is theoretically 5.99knots... my GPS has locked me at 6.5 on a reach. Again average over 2 minutes.
SHNOOL is offline
post #12 of 23 Old 10-17-2011
jackdale's Avatar
How much current is present?
jackdale is offline
post #13 of 23 Old 10-17-2011
St Anna's Avatar
0.8 amps
and 0.51 kn
St Anna is offline
post #14 of 23 Old 10-17-2011
Senior Slacker
SlowButSteady's Avatar
The quotes from Gary Mull pretty much sum up why "hull speed" shouldn't be called "maximum hull speed". Let me just add a bit to why hull speed works as a concept. As a displacement hull moves through the water it creates a wave, which boaters/sailors usually call the "bow wave" or "bow wake". This bow wave initially has a celerity equal to the velocity of the vessel. The celerity of a wave actually slowly increases with time, but we only need to worry about what happens when the wave is first created. The wavelength of a surface wave is proportional the celerity of the wave; the faster the wave, the longer the wavelength. There is actually a fairly complicated formula for this relationship, involving the celerity, the force of gravity, and the density, viscosity, and surface tension of the water. But, since everything is pretty much constant except celerity and wavelength, the whole thing boils down to C = 1.34*sqrt(wavelength).
Now, what exactly does that mean? As the boat moves through the water the wavelength of the bow wave gets longer as the boat moves faster. The first crest is always at the bow, with the next crest being one wavelength aft of the bow. When the speed of the boat (and hence the celerity of the bow wave) increases to the point that the next crest is near the stern of the boat this crest is often called the "quarter wave", but it is really just the second crest of the bow wave; the stern quarter isn't causing the wave, it's being cause by the bow. The velocity at which this crest is right at the stern is called the "hull speed" or HS, and is described simply by substituting HS for C and length at the waterline (LWL) for wavelength in the above equation, to get, HS = 1.34*sqrt(LWL). The important thing here is what happens when the boat is going fast enough (and hence the bow wave has a high enough celerity) that the wave has a wavelength longer than the dynamic waterline of the boat? Now the stern of the boat will no longer be riding on the second crest of the bow wave (or on the quarter wave, if you prefer), and the boat will have to pitch up slightly. This takes a power input to maintain speed and so the power/speed ratio of the boat increases due to this added factor. The power/speed ratio has been increasing with speed all along due to other factors, but now this increased pitch of the hull and the forces generated by the bow having to push "through" more of the initial crest of the bow wave causes a sharp increase in the relationship.
So, it always takes more power (energy/time) to make a boat go faster, but above hull speed the relationship between power and boat speed gets steeper and steeper. This is essentially because above hull speed the boat is forced to climb is own wake. Next time you're in a planing boat you can actually demonstrated this. Give the boat a bit of gas and initially the bow will pitch up, the stern will squat down, and it will feel like the boat is trying to climb out of a hole. Give it enough gas and the boat will "jump" onto a plane and the rules will suddenly change; once the hull is actually planing you can ease the throttle back a bit (lower the power) and stay on the plane fairly easily. But, kill the engine (or go to idle) and the boat will plane for a bit then suddenly slow as it can't maintain a plane anymore and has to crawl up its bow wake, until it gets below hull speed again and more easily glides along as a "true" displacement hull again.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #15 of 23 Old 10-17-2011
HANUMAN
RobGallagher's Avatar
Originally Posted by NewportNewbie View Post
I am curious as to how accurate this is at determining your max sailing speed. My hull speed from the manufacturers states 6.5 knots...I can get to that pretty easily, I would have thought that it wouldn't be that easy to get to the max speed. This was actually close hauled into the wind...I know you can get way above that downwind and surfing the waves. This speed was from my GPS and that was averaged over 3 minutes so it wasn't just a spike at that 6.5 speed...it was an averaged speed. With some tweaks to sail trim and a very clean bottom I'd think I can get to 7.5. Where some manufacturers more conservative with rating the hull seed? Or is it maybe modern sails and rigging make it actually possible to sail above hull speed? Or am I thinking too much and just enjoy that I can get the boat moving like that!
As others have said, you need a knot meter. If there is current where you sail it will effect how fast you are going through the water.
RobGallagher is offline
post #16 of 23 Old 10-17-2011
JedNeck's Avatar
SlowButSteady...Thank You!!!
Until your post I didn't understand how a boat's waterline could be the only "boat dimension" variable that could affect speed...
My Sea-Doo boat is a great example of what you're saying...putts along at idle nicely...give it a little throttle and it hits the wall...now I can bore my crew with the reason why. =)
JedNeck is offline
post #17 of 23 Old 10-17-2011 Thread Starter
NewportNewbie's Avatar
Ok...great discussion, so let me get this...I understand that there is a difference between boat speed which may be aided or impeded by currents, but just raw speed GPS should be far more accurate. How long does it take to get from point A to point b and figure out is speed in knots based on that. That should never change...right? So a knot meter on a boat will tell you how fast the boat is moving (or more exactly how fast the water is moving past the boat) and will give you instant results in regard to sail trim. A GPS device should give you the actual speed, not boat speed.
S/V Cuajota - 1975 WD Schock Santana 30
NewportNewbie is offline
post #18 of 23 Old 10-17-2011
4KSB driver.
In my case 0, or rather negligible... man made lake. Numbers are sailing cross-stream anyway (if you can call it a stream).
SHNOOL is offline
post #19 of 23 Old 10-17-2011
4KSB driver.
Newport... you hit it right on the head. Most people want GPS for navigation, and ETA, not for speed perse' But knowing SOG is essential for ETA, and travel times. It is just as significant for boating, however, Speed over Water, is essential for all of us as well because it tells us our best trim settings for a given wind (assumes steady wind).
You are now starting to get JUST how complicated sailing can be (about as complicated as you let it)... for those of us (most of us, even the so-called cruisers only) who are after the "perfect trim," it is a life-long unachievable goal. You are catching it now... Don't let it rule you, but don't give up on it either. It'll make you a better sailor. It will make ALL of us better sailors.
Don't get "instrument i-tus" either. Gadgets are cool, but remember they are a modern phenomena. The old-salts sail without them, and can smoke some of the young punks using all the gadgets. A knot-meter, and a depth sounder are pretty essential gadgets though, and a great start.
I am with you though, I JUST have a GPS (actually my phone running navionics)... my goal this winter though is to get a knot and a depth gauge to get me better information on my sailing. Will I still use my GPS (absolutely), but those hard instruments I feel are pretty essential for me going forward.
SHNOOL is offline
post #20 of 23 Old 10-17-2011
emoney's Avatar
On my powerboat, I checked my GPS vs. the speedometer (hey, it's measure in mph so I couldn't say knotmeter) and there was a 5mph difference betwixt the two. Question was, which one was correct?
I'm sure there's a lot of technical reasoning in this debate, but ultimately I'd surmise two things: 1)don't 'just' trust your GPS for actual speed 2)don't care about speed, just go as fast as you can.
emoney is offline
C&C 24 hull speed? PaulinVictoria General Discussion (sailing related) 7 06-17-2010 12:41 PM
Hull Speed? PalmettoSailor General Discussion (sailing related) 38 08-10-2007 05:14 AM
Hull Speed timangiel General Discussion (sailing related) 35 07-24-2007 10:08 PM
LWL and Hull Speed flicker General Discussion (sailing related) 2 12-03-2003 08:41 PM
Hull Speed Sailormon6 General Discussion (sailing related) 11 08-03-2002 09:16 AM
