Like Tree11Likes
  #71
Old 10-26-2011
MarkSF is on a distinguished road
If you do change boats, get a nice classic cruiser like this :
1983 Bristol 38.8 Sail Boat For Sale - www.yachtworld.com
You won't believe how much more sea-kindly they are.
Bristol 31.1
  #72
Old 10-26-2011
Ninefingers is on a distinguished road
Hey Newport, before you do anything hasty, may I suggest something, well...less hasty
Have you thought about joining Sailtime for a year before you decide on another boat? The base at Newport has 33, 36, 38, and 44 foot Hunters, all virtually new. If your wife can't fall in love with sailing after a season on of those, your probably out of luck.
There is one in Newport:
Newport Beach Sailing at SailTime Orange County
  #73
Old 10-26-2011
hellosailor's Avatar
hellosailor has a spectacular aura about hellosailor has a spectacular aura about
"I am really trying hard to figure out a way that she can get into it more."
I suppose a ketamine martini would be politically incorrect?
Sounds like you'd best keep sailing with the boys and take the missus out only on windless days with flat water. Unless she really means, the chop is making her seasick, in which case there are often remedies.
  #74
Old 10-26-2011
TakeFive's Avatar
Used to be RhythmDoctor
TakeFive will become famous soon enough
I have a buddy who really thinks he know how to sail. He rents a daysailer once every year or so when vacationing at Martha's Vineyard. He mostly singlehands because his wife refuses to get on a boat with him.
First time we invited them on our boat, I learned why she refuses to sail with him. (She agreed to come this time because he wasn't the skipper.) He first complained that the we were wimps for reefing, so we shook it out to accommodate him. Later, every time I looked away, he was pulling on the mainsheet to trim the main as tight as he could get it, even though we were on a reach. He got the boat up to about 40 degrees heel (and much less than hull speed) before I ordered him to keep hands off the sheets and let my wife do it.
A year later we went out together because my wife was out of town and I needed crew. He did the same thing again, and didn't want to reef for the conditions, arguing that "we would lose power." I told him that once we hit hull speed, any extra power was wasted on turbulence and dragging the hull form down in the water. I also told him my hull design is made to sail optimally at 15 degrees, and heeling beyond that pushes the belly of the beam down into the water (more drag), as well as having to constantly fight the rudder to prevent rounding up (more drag again). I reefed, loosened the sail trim, got the boat back to 15 degrees, and increased our speed by 1/2 knot with a much more comfortable ride and no weather helm.
In retrospect, it seems this guy is used to sailing planing boats, and knows nothing about the limitations of displacement boats.
I don't know how much the OP knows about his own boat, but it sounds like he might be overpowering his boat, which generates an uncomfortable ride, disgruntled crew, potentially dangerous conditions, and will still not succeed at exceeding hull speed.
A bigger boat is harder to overpower, but it's an expensive way to solve a problem that might be more easily solved through refining your sailing skills.
1998 Catalina 250WK "Take Five" (at Anchorage Marina, Essington, on the Delaware River)
1991 15' Trophy (Lake Wallenpaupack)
  #75
Old 10-26-2011
NewportNewbie's Avatar
NewportNewbie is on a distinguished road
This for the advice...The heel angle isn't at all the issue...it was the up and down motion of the bot over and through the waves. Like I said it was a tad bit choppy. I asked her if it was the angle and even adjusted the boat so there was less heel through the traveler, but she insisted it wasn't the heel angle, it was the up and down. She said she wasn't scared and wasn't worried, she just had to hold on too much for her liking. We looked at a few ads for newer/bigger boats and when it was all said and done she didn't see anything that compelled her to want one more than the boat we have. So I will take her out early in light winds...and save the choppy stuff for the fellas.
S/V Cuajota - 1975 WD Schock Santana 30
  #76
Old 10-26-2011
TakeFive's Avatar
Originally Posted by NewportNewbie View Post
...The heel angle isn't at all the issue...it was the up and down motion of the bot over and through the waves. Like I said it was a tad bit choppy. I asked her if it was the angle and even adjusted the boat so there was less heel through the traveler, but she insisted it wasn't the heel angle, it was the up and down...
OK, sounds like you know how to avoid overpowering. I'll leave my post up anyway since others look here for advice also.
I hae one other comment that might be helpful to you or others. I had to add 300 lb of ballast in the bow of my little boat to make her sail on her lines. This fixed a hatch leak (since the the hatched was designed for rainwater to drain forward off the foredeck), greatly improved visibility (since the bow was lower), and reduced weather helm (since the mast was raked less). One unanticipated improvement was that it greatly reduced hobby horsing.
300 lb. may not be much for a boat your size - my boat is known to be a lightweight design. But some additional ballast in both the bow and stern (balanced to keep her on her lines) would increase the moment of inertia of your boat, and might reduce hobby horsing for you. However, you should consult other owners of your boat to compare notes on what's safe and effective for your particular boat.
  #77
Old 10-26-2011
apogee1mars's Avatar
apogee1mars is on a distinguished road
Originally Posted by AdamLein View Post
Gazelle is for sale (2008 Gunboat 66 Sail Boat For Sale - www.yachtworld.com).
Anybody wanna go in as partners?
Don't most large cat's end up upside down floating around in the Sargasso Sea eventually?
  #78
Old 10-26-2011
WDS123 is on a distinguished road
Newport,
Sounds as if you do know how to manipulate sails to depower - good !
In waves/chop one can steer to reduce the pitching and amount of spary coming over the bow by working the tiller plus/minus 3-7 degrees.
Upwind - steer diagonally up the wave face and then straight down the back of the wave.
  #79
Old 10-26-2011
Originally Posted by WDSchock View Post
Newport,
Thanks! I will try that next time I'm out there. I was going through them somewhat straight.
You may post attachments
You may edit your posts
Cascade 29 - Good deal/Bad deal? jcwhite Boat Review and Purchase Forum 3 04-24-2011 12:49 AM
Pearson Wanderer - Deal or No Deal? laHolland Boat Review and Purchase Forum 52 01-01-2011 04:10 PM
DEAL!? OR... NO! DEAL!? O'Day 23' OceanSailor4 General Discussion (sailing related) 5 07-01-2010 09:59 PM
breaker box QuickMick Gear & Maintenance 18 12-09-2009 09:03 AM
Citation 34 - deal or no deal? kenny0330 Irwin 5 11-18-2009 03:34 PM
SEO by vBSEO 3.6.1
