Personal Anchor Data - Page 2 - SailNet Community
 4Likes
post #11 of 20 Old 10-26-2011
Originally Posted by orthomartin View Post
CQR: Ave drag 42', set 10% (19 of the 180. Almost all on their sides)
Delta drag 21", set 21% (101/128)
Bruce drag 22' set 22% (82/92)
Rocna drag 8' set 92% (59/64)
Spade drag 6' set 98% (59/60)
Mason drag 8' set 96% (49/51)
It seems very interesting but it seems that I am the only one that does not understand completely your information. Can you explain it to me?
when you say Ave drag 42' and Ave drag 8' what do you mean? That they drag for 42', that they take 42' before starting to drag? I don't understand what you want to mean in either of the cases.
Regarding set, it is clear to me but it seems that a very relevant peace of information is missing: The percentage of anchors from each type that you have saw dragging.
post #12 of 20 Old 10-26-2011
With all due respect, while I find this interesting, I don't know how it can be taken seriously and the OP doesn't seem to be trying to call it scientific anyway.
I assume the average drag was a witnessed burrow in the bottom that leads up to the set anchor. How it was witnessed, measured, or estimated is suspect, as water distorts visual distances by 25%.
I can't help but wonder how one identifies a set manson from a set rocna in sand. They would typically be buried beyond recognition. Not even sure you could tell a spade from a delta if both were actually set. Maybe they were witnessed going up or down the bow roller.
It sure does seem like a bad hobby.
Jeanneau 54DS
Minnewaska is offline
post #13 of 20 Old 10-26-2011
For the record, after the first year I gave my CQR away and bought a Spade but to each his own. I hope this info is helpful. It was fun collecting!
Just wondering, since you had the CQR for at least a year and it seems to have terrible statistics, did you often find your anchor not securely set? Did you find it difficult to set? And then when you changed to a Spade did the process become noticeably better for you?
dinghycapn is offline
post #14 of 20 Old 10-26-2011
In hard sand anchors rarely bury below the surface. They wont do that on engine power alone. The difference MS and Rocna are reasonably easy to pick because of the slot in the top of the MS anchor shank. The Spade has a distinctive shape and is hollow in all but the smallest models.
The estimates of drag distance are not going to be perfectly accurate, but diving there is an enormous apparent difference between the new generation anchors which nearly always set in very short distance and say a CQR which rarely sets in less than a boat length (if it sets at all) in hard sand.
noelex77 is offline
post #15 of 20 Old 10-26-2011
My experience with a plough (CQR copy) and Rocna, may be helpful. I very rarely achieved other than a very marginal set with the plough in hard sand or weed (the most common anchorages here). The anchor was oversized for our boat. It never dragged in less than 35K, but also never held above 45K (this is mean wind the gusts would be at least 10K higher. This means we would expect 4 to 5 dragging incidents a year.
It often required several tries before it would hold 1/2 cruising revs in reverse.
The plough was replaced by a Rocna 1 size bigger than the plough (so 2 sizes larger than recommended). It has not dragged in 3 years. It is very rare it does not set first time and usually there is a reason (last time was couple on months ago and it landed on a tree !). We now apply full reverse for 30 seconds so the criteria is tougher.
Its very rare I would not define the anchor appearance when diving as very well set.
noelex77 is offline
post #16 of 20 Old 10-26-2011
PaulfromNWOnt's Avatar
Nope, nothing scientific, just observations taken over a period of time and presented here with no results claimed.
Great! Just adjust each number equally by 25% and go from there. It really isn't that big a deal since the curve would remain the same.
He's CrUiSiNg... They are typically friendly people aren't they? Perhaps... wait for it.... He AsKeD??
But it's his hobby. Perhaps you might like something different.
I personally like the initial post, and am happy to have the extra information.
PaulfromNWOnt is offline
post #17 of 20 Old 10-26-2011
AdamLein's Avatar
Thanks very much for sharing your observations. I think more observing, and less snickering about other people observing, would overall be an improvement.
However I too am curious about how you got the drag measurement. Is it purely from diving and looking at the furrow?
Another thing: I had initially assumed that you just went all MaineSail, bought all these anchors, and recorded the results for your own sets. Is that the case? Or are you including sets that you noticed of other peoples' anchors?
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
post #18 of 20 Old 10-26-2011
skygazer's Avatar
From original post:
These areas provide very clear water so normally after setting anchor I snorkel and check the set. When in the crowded Adriatic (croatia) I started checking surrounding boat anchors to see whom was going to drag on us in the night I started collecting data on what anchors, how long the drag before set, and how often it was what I called "set". For me that was about 3/4 of the surface area buried.
skygazer is offline
post #19 of 20 Old 10-27-2011
AdamLein's Avatar
Originally Posted by skygazer View Post
From original post:
I did read the original post. But saying "I looked at X. I then collected this data: Y" does not imply that the observation of X was included in data Y. Maybe he was simply inspired to start keeping track of his own anchors' performance after seeing other peoples' sets?
Considering how it's not uncommon for the regular posters on this forum to see ignorance in the world and then do some experiments and publish results to correct that ignorance, this seems plausible to me.
How each reader chooses to interpret the results should depend a little bit on whether the sets were all done by the same person.
AdamLein is offline
post #20 of 20 Old 10-27-2011
Originally Posted by PaulfromNWOnt View Post
......He's CrUiSiNg... They are typically friendly people aren't they? Perhaps... wait for it.... He AsKeD??...
Therefore, I assume the tone of this reply would exclude you from being a cruiser.
I was kidding about his bad hobby as the smiley was to denote.
Jeanneau 54DS
Personal Loans? ImASonOfaSailor General Discussion (sailing related) 15 08-06-2011 11:35 AM
Personal Hygiene ystanley herSailNet 23 11-19-2010 12:08 PM
Personal GPS locator rockDAWG General Discussion (sailing related) 15 10-08-2010 10:18 AM
Personal Locator Beacons BlueWaterMD Gear & Maintenance 7 11-21-2007 04:51 PM
