10-29-2011
Tacky yet Unrefined
The "Lady" and I
We're getting closer...
This is the first chance I had to spend a little time getting to know her since I dragged her home from DC...
I emptied her out of all the accumulated nick nacks and collectables from the PO getting to the bottom of all the bins and hidey holes... Pulled all the cushions and PFDs and removed all the hatch and bin covers so I could take stock of what was left..
Then I tried out the electrical...Made up a 30 amp plug so I could hook up the AC power and checked out the outlets.. all good there.. then we went to DC...
I have a "Redi-Amp 8" auto charger that seems to be shorted internaly, keeps popping the circut breaker, I disconnected it from the battery switch and it does put out power but still pops the breaker, so I'm thinking of sending it in for service...in the meantime I removed it from the boat.
Both batterys were dead, so I pulled them and tossed in a temp starter battery to test the DC circuts. Cabin lights work, VHF came on, Bildge pump works, running lights and mast light checked out OK.. What is the "Bow Light" that one didn't go anywhere.. ?
While I was "in" the starboard cockpit locker, I removed a mile or so of extra wires, a combination of phone line (?) speaker wire and a couple power wires that went "nowhere" cleaned it up nice and makes a lot more sense now...
Went in the cabin and pulled a few more "unused" wires and pulled up the floor panels.. keel bolts all clean and accessable but my centerboard seems to be "stuck" in the up position...
I think when I have the crane lift it off the flatbed I brought it home on I'll get underneath and run a long blade down both sides of the keel removeing the crud and hopefully that will allow the CB to drop, then I can reattach the lift rope to the cable and pull 'er back up...
Next warm day(s) I get I'll check out the plumbing, and run a little RV antifreeze thru it for the winter...
Little by little I'm makeing her my own...
Will post updates as they come..
