10-31-2011
We've had poor results with screws in a cored deck, even with 3M 4200 bedding. Through-bolting (with the same bedding compound) seems to work better, along with the appropriate backing plates or washers, to spread the loads. Pilot holes for screws are invariably drilled too small, leading to expanding cracks when the screws are driven. The screws have nothing but the thin exterior layer of fiberglass (1-2mm. if that) to grip, since the end-grain balsa has no holding strength. They therefore pull out, or crack the fiberglass beyond the bedding, which allows moisture to enter the deck, which then begins to delaminate. The Gougeon brothers (West System guys) suggest creating an oversize hole, filling it with thickened epoxy, and inserting a waxed (so it can be unscrewed) screw into the liquid epoxy until it hardens. THEN attach your fitting.
